Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Brush does not touch floor when handle > 45 degrees
When the handle is greater than 45 degrees from upright, the rotating brush does not touch the floor and vacuum performance is greatly reduced. It seems like there should be a spring or something to cause the brush unit to move toward the floor.
  • 372 Answers
Hi.
I have come accross this a few times over the years,
I have found that the only way to rectify this is to fit new internal hose (short transparant hose under machine)
When a new one is fitted the spring coil action from the hose pushes head flat down to floor.
Hope this helps you.
http://dysonmanuals.llc.nu/
Chris.
Posted on May 04, 2008
Brush bar stops rotating when I recline the upright part beyond 45 degrees. Brush bar rotates but if I move the machine too far away, increasing the angle it stops. All cleaned out etc
There is a switch in the ball which is activated as you pull the handle back from the upright position. The lever that activates the switch pivots as the handle rotates backwards. Try to determine if this lever could be broken or mislocated somehow..
May 02, 2016 | Dyson DC40 Multi floor Upright Vacuum...
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    How to repair windtunnel hoover agitator that will not turn
    Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
    Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
    I cleaned the brush took the whole head apart put it back together now it wont pick up anything. plus it only works whennyou release the handle
    Hi Jennifer, it's Jack at Dyson.
    Like most current Dyson upright vacuums, DC40's brush bar is engineered to shut off for protection if something jams it. Although I appreciate you've already checked the cleaner head for any issues, you might like to do so again following the steps shown in the Support video I've attached. You should then be able to reset the machine.
    Please note, the brush bar will never rotate when the machine is standing upright, so please recline it into the normal vacuuming position before testing it. With the machine running, press the silver brush control switch twice.
    You may also like to check for any blockages which could be effecting pickup performance. Just follow the steps shown in our online troubleshooting guide: http://www.dyson.com/support/dc40/dc40-multi-floor/my-machine-is-not-working/machine-not-sucking-up-well
    If you're still having difficulty after you've given this a try, it would be best if you can get in touch with us directly so our experts can provide further assistance. Dyson upright and canister vacuums come with a 5-year warranty, and if a repair or replacement part is needed we'll be happy to confirm if this is covered.
    You can reach the Dyson customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Mar 27, 2014 | Dyson DC40 Multi floor Upright Vacuum...
    All belts are good but brush will not turn
    Hi Nabil, it's Jack at Dyson.
    If you have a DC14 and the brush bar isn't rotating, it's worth checking to make sure the brush control on the cleaner head is set to 'Carpets', and not 'Hard floors'.
    http://www.dyson.co.uk/support/dc14/dc14-all-floors/my-machine-is-not-working/i-can-see-something-wrong-visual/i-can-see-something-wrong-visual/my-brushbar-is-not-rotating2/does-the-brushbar-turn-with-the-power-on
    Tip: The brush bar will never rotate when the machine is standing upright, so make sure you recline it down into the normal vacuuming position before testing it.
    If you're confident the brush control is set correctly, but the brush bar still won't rotate when the vacuum is reclined, please get in touch directly so we can help further. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Best wishes,
    Jack
    Dyson Online Customer Support
    www.dyson.com
    Aug 19, 2013 | Dyson DC14 All floors Bagless Upright...
    My brush is not rotating
    Hi there, it's Jack at Dyson.
    I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
    I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
    If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Best wishes,
    Jack
    Jul 21, 2013 | Dyson DC-33 MultiFloor Upright Vacuum...
    Brush does not rotate
    Hi Sharon,
    I'm sorry to hear you're having difficulties with your DC07. Please note, the brushbar will never rotate when the cleaner is standing in the upright position, or if the brush control is set to 'Hard Floors'. Please check you have the cleaner reclined into the vacuuming position, and that the brush control is set to 'Carpets'. If the brushbar is still not rotating, it's probably best if you get in touch with us so we can provide further assistance - you can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Nov 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    DOES THIS SWEEPER HAVE A BELT MY BRUSHES ARE NOT MOVING
    I'm sorry to hear you're having difficulties with your DC14 All Floors. This model does not use a standard replaceable belt, but a clutch system which allows you to turn the brushbar off for cleaning hard floor surfaces. The brushbar never rotates when the cleaner is standing in the upright position, or if you have the brush control set to 'Hard floors'.
    If the brush control is set to 'Carpets', but the brushbar does not rotate when the cleaner is running and reclined into the vacuuming position, it's probably best if you get in touch with us directly so we can resolve this issue for you as quickly as possible. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Sep 14, 2011 | Dyson DC14 All floors Bagless Upright...
    The dc25 brush does not rotate
    Is yours the yellow model? There should be two large "half buttons" blow the handle in the front. One turns the vacuum on without the brush. the other turns it on with the brush.geemarie.jpg
    Jan 02, 2011 | Dyson DC25 All Floors Bagless Upright...
    While operating machine, brush does not rotate. Button is pushed in, all hair cleaned off brush. Is there a reset button? Where is it located?
    Likely the wires are broken under the left hand cover not a difficult fix. Unplug the machine and remove the 4 torx screws and an access panel at the side of the ball. replace wires with new or re-connect with a splice. ensure wires are long enough to allow movement and you don't trap the wires when you replace the covers. about a 20 min job with the right tools
    Sep 26, 2009 | Dyson DC15 All Floors - The Ball Bagless...
    Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
    124 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
