Question about Tower Chambrer WC601S 7 Bottle (6+1) Thermoelectric Wine Cooler, Silver
Lost the manual don't know how to set temp on the cooler
Avanti outdoor beverage cooler (new), should temperature lights go off? How do I know what the temp is, if the lights go off? It appears to go off for no reason. Owners manual mentions door gasket?? I
The temp lights might indicates the actual temp settings havent reach the programmed settings. If its on and off coz it try to recover the temp lose after it drop below prog. Temp. Monitor it first if its cooling must be normal only.
Sep 21, 2014 | Avanti Orc2519ss Steel Outdoor Beverage...
What is the lowest temp that the cooler has.
If you got this new, You should have a manual with the hi-est and lowest temp setting in it...If you do not have the manual than you can Google the same question on google search and get a manual,or a forum where they talk about this model.
Mar 07, 2011 | Emerson (025806803716) Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Haier wine cooler, how to operate? No manual.
If you just want to use the factory settings then push the red or white button depending on what you store the most.
Or you can set it yourself by pushing the red and white buttons together for about 3 seconds- the temp display will start flashing-then use the red and white buttons to set the desired temp-then push the set button
Jun 11, 2009 | Haier HVF060A Wine Cooler
F 31 Frigidaire gas range
if it cooler that the temp set its the theromstat f31 sorry don.t know
Dec 20, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Westinghouse fridge
cooler means coooler cabinet temperature...
Feb 12, 2008 | Refrigerators
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Oct 18, 2007 | Haier HVF060A Wine Cooler
Refrigerators Logo
47 people viewed this question
Top Tower Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Tower Refrigerator Expert? Answer questions, earn points and help others
