Question about OTC 3183 Digital Battery Tester
What does the display b l on the meter mean? - OTC 3183 Digital Battery Tester
  • 4 Answers
Its a faulty connection!
Once the tester is ready, if a connection looses continuity, then a message will identify the clamp that has a bad connection: Red (rd) or Black (bl).
Posted on Oct 18, 2011
What is a E-1 code for an ACCU-CHEK meter?
"E-1" in the display means the test strip may be damaged or the code key is incorrect. Remove and reinsert the test strip.
Jun 29, 2017 | Health & Beauty
The meter says E 5 on it what does this mean ?
Cant remember exactly but i think that is probable blood incorrectly put onto test strip, probably before meter is ready. You have to wait for the little drop of blood to appear on the display.
Mar 15, 2015 | Accu Check Aviva Plus Blood Glucose...
No power and cracked display is it related?
Dale, If your charger starts flashing very fast, or no light is coming on at all, something is wrong. No light coming on, could mean it does not get any power. But it also could mean the battery has died.
If you have a multi meter, you could test what voltage the battery has. Most batteries are 3,7 or 7,2 volt. when you use a multimeter, the reading in DC should be something like 3,9 or 7,5. On the meter the outage should be a few percent higher than what is printed on the battery. As soon as the meter indicates a voltage just a little (or worse a lot) under the printed value, the battery must be replaced.
Apr 25, 2014 | Nikon 1 J1 Digital Camera
Service Code F-3
The error code's F3&F4 are codes that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F3 error code means that the sensor is shorted so if it indeed is shorted the meter reading will show ZERO ohms resistiance instead of the 1060-1100 of a good one.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If on either the F3/F4 error code if at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
Nov 30, 2011 | Magic Chef Ovens
My oven is comimg up with the F4 fault message?
Hello Rose,
The error code F4 are code that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
If at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
GENE
Oct 19, 2011 | Ovens
Error code F3 E5 when using self clean cycle
Error Code F3 - E5 - Oven temperature sensor (RTD) shorted (lower oven, if double oven)
Replace Oven temperature sensor (RTD) or Thermal Fuse.
Hope this helps.
Oct 08, 2011 | KitchenAid Kitchen Ranges
What does erroe f7 mean?
Hi
This error indicates a fault with the water flow meter. F7 means inlet flow meter malfunction
Remove the left panel and check the flow meter, try to unplug it and plug it again.
If not OK, change the part, If you have checked the sump filter at the bottom of the dishwasher, then close the door and turn on the power. Then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Whirlpool Dishwashers
When checking the meter reading on my canon ir c5185, there are the following codes before the totals: 101 102 108 230 321 322. Can you tell me their meanings?
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Jan 07, 2011 | Canon Office Equipment & Supplies
Possible blown dryer thermal fuse
to check thermo fuse set digital meter to a low resistance setting typical 200 " omega symbol" on most digital meters the 200 setting also has an audio beep for continuity which means that if the fuse is good it will beep and also show on the display a zero out, and if fuse is bad there will be no beep and the display will show a 1. good luck.
Dec 31, 2009 | Actron Digital Multimeter Tester
OTC 3183 Digital Battery Tester Logo
374 people viewed this question
Top OTC Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an OTC Measuring Tool and Sensor Expert? Answer questions, earn points and help others
