Question about RCA D52W19 52" Rear Projection Television
I have a RCA telivision Model # J25420 that refuses to respond to the commands from the remote control. It stays in unusable signal and will not leave that mode. It will not go into menu mode so that i can reprogram it.
  • fancherfamil Aug 19, 2010
    The screen says unusable signal and function disabled. Nothing else happens when I press
    the Menu button. Could it be a problem with the Microprocessor or memory?
    Haven't heard from anyone in a while. Can your experts solve my problem?
    I have a RCA television model # J25420 . The television does not respond to the remote or menu button.
    The screen only shows unusable signal, and function disabled.
    I purchased it from a hotel and it worked fine in the hotel.
    HELP!!!!!
  • RCA Master
  • 5,807 Answers
It seems you have a bad EEPROM IC if you have a good
remote matching your TV or a bad IR sensor.
• remote like one from here:
http://salestores.com/rca24maserec.html
• EEPROM
http://en.wikipedia.org/wiki/EEPROM
Posted on Aug 20, 2010
  • 4,889 Answers
Does this happen when you are using front panel controls too?
Posted on Aug 19, 2010
  • 1 more comment
  • eagle338
    eagle338 Aug 19, 2010
    Its too pre-mature to conclude that. Did you try another video source such as a DVD-Player or something to see if the problem persists?
    Yes I did and the same problem exists. I purchased the tv from a hotel, and it worked fine.
  • eagle338
    eagle338 Aug 20, 2010
    Well in that case the I do think you were right. The processor is called EEPROM and can be re-programmed by qualified personnel. I suggest that give it a shot to see if thats fixable. Otherwise you may just wanna get a new PCB mainboard.
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
I need the maual for this rca tv L37wd22yx6 tv just keeps saying unusable signal and i need the maual
What is the signal source for the TV? Make sure that you are on the correct input. Use the Input button on the remote. If you do not have the original remote, you need one that matches that function. (Often a Source or Input button is not available on the low end remotes.) Check that you have the signal set to Antenna or Cable if you are using the coaxial connection and the source is TV. (Menu > Setup > Channel Setup > Signal Type)
If your source is a computer, use the VGA port not the HDMI port. Computers send a different type of video signal than video set top boxes. The L37WD22 can't interpret the PC signal on the HDMI input.
For a set top box on the HDMI port, the unusable signal message indicates a communication issue. Try pressing the Info button on the remote. If you see an additional message of Acquiring Channel, then the set top box isn't responding to the remote. Check that the device is on and set up correctly to communicate with the TV. (For example, if your set top box offers progressive scan, try turning of that feature with the control for the box.)
The L37WD22 was built by TTE for the RCA label. The manual is available on the TTE support page.
The direct link to the User's Manual in English is http://support.ttetech.com/RCATV/Assets/pdfs/L37WD22_16788070_IB_e-07.pdf .
I hope this helps.
Aug 29, 2011 | RCA Televison & Video
I just got a rca tv j25420, how do i add channels? it is only set up with 13.
U must have the tv original remote to do that.Try website like Remotes.com to buy the tv original remote.
Aug 19, 2011 | RCA F19253BC TV
I HAVE A J25420 TV WHICH I BOUGHT FROM A HOTEL AND I LOST THE REMOTE CONTROL. WILL ANY UNIVERSAL RCA REMOTE WORK FOR THIS TV ?
Pretty much. This nice thing about RCA stuff, more than any other brand, is that the universal remotes they sell will run their equipment without (most of the time) the need to try additional RCA codes. I know this from personal experience.
Feb 28, 2011 | RCA F19253BC TV
I NEED A NEW REMOTE CONTROL
Hello
I thinks that you need a new universal remote control for your RCA tv, and answers. You just buy one stated below,and codes and other proceedings are also given.
Model No: [RCA - D770 Wide Range Remote Control]
Codes for RCA TV with this remote control are:-
1000, 1003, 1004, 1005, 1006, 1007
.........................1019, 1096, 1098, 1099, 1100, 1101
.........................1102, 1103, 1129, 1179, 1181, 1187
............................................1188, 1190, 1198, 1199
Proceedings
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn't, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
NB: Switch Off and On your TV with its front panel power switch each time [NOT BY THE REMOTE CONTROL HANSET], before you try an other code, UNTIL YOU GET THE RIGHT ONE.
Dec 20, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I have a 42" flat screen. Only two years old.. It just went black during a movie and won't do anything. When I unplug it and plug it back into the wall the light just stays blue... No access, picture, nor...
Try leaving it unplugged overnight; it may have an IC locked up.
If that doesn't work, it is likely a power supply problem, these are all too frequent with our sets.
There are at least two supplies in your set; one of them (a low-voltage section or board) stays on continuously so the set can respond to commands from the remote. The other is turned on when you power the set up via remote or button push.
If the set isn't responding to either remote or local set controls, it is likely that the main power supply has failed.
Your help request is captioned as a 52" model number but your text says it is 42" so you need to add the correct model number before anyone can help you.
Aug 22, 2010 | RCA HD52W59 HDTV Projection Television
RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Sep 24, 2008 | RCA 244889 Remote Control
I need codes for a rca d770
Programming For TV
commands. If it doesn’t, try pressing the device button
Emerson ..................1004, 1006, 1012, 1014, 1023
..................................1024, 1025, 1026, 1027, 1028
..................................1029, 1030, 1031, 1033, 1034
..................................1035, 1036, 1038, 1039, 1041
..................................1042, 1043, 1044, 1046, 1047
..................................1123, 1124, 1162, 1171, 1176
......................................................1177, 1179, 1191
Your user manual is available for download and option printing at the following link :
http://www.retrevo.com/s/RCA-D770-Universal-Remotes-review-manual/id/402ci568/t/1-2/
May 16, 2008 | RCA D770 Remote Control
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
Universal Remote RCA RCR4258/RCR4358 is locked
I am trying to get the auto programming for RCR4258 Remorte sincve I have moved I lost My Instructions to remote.
Feb 16, 2008 | RCA RCR450 Remote Control
RCA D52W19 52" Rear Projection Television Logo
160 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
