Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Frigerator runs constantly but is not freezing or cooling
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 19, 2010
The model number on our frig is RT21LMXKQO5. Water is constantly dripping from the freezer into the frigerator.We put a towel on the top shelf of the frigerator and the water ends up freezing on the towel....
You have a plugged defrost water drain. you will have to turn off unit, remove evaporator panel in freezer and **** out/clear drain hole for defrost water. pour some hot water down drain. Not an expensive repair you may want to get someone mechanically inclined to help
Jun 22, 2011 | Roper Refrigerators
The frigerator & freezer are not cooling properly . i hear the compressor running . i have also diconnected cleanned inside and out but still the unit is not cooling properly . even on higest settings
If the compressor is running almost all the time (and the compressor sounds ok - no pinging/clunking),
then your side-by-side has developed a coolant leak.
When a system is low on coolant, the thermostat detects the warm condition of the refrigerator, and
runs the compresor motor in an attempt to cool off the refrigerator compartment, but if there's little
or no refrigerant in the system, the system's attempt to cool off the refregerator/freezer will fail,
with the symptom that the user wil hear the compressor motor running constantly.
May 13, 2011 | Kenmore Side by Side Refrigerator
The frigerator isnt working but freezer is how can i fix it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Refrigerators
IT WILL NOT COOL OR FREEZE, DIGITALPANEL IS SHOWING 52 TOP AND 39 IN FREEZER. FANS ARE GOING BUT NO COOL AIR NOR IS THE FRIGERATOR RUNNING. ECH SAYS NEW COMPUTER BOARD IS NEEDED IS THIS TRUE?
I was having the same problem .What I found was the coils were dirty and needed to be clean also the overload relay switch and the capacitor were bad.The overload relay and capacitor are next to the compressor. Replace them and you should be cool again.
Mar 05, 2010 | KitchenAid Architect KBFA20ERSS Stainless...
Samsung rs2530bbp... Not cooling... Compressor
my frigerator RS2530BSH has the EXACT same problem! can anyone help??
Jan 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Freezer freezes and won't cool either freezer or refrigerator.
On my GE side by side (model GSS20IEMDWW), the evaporator coils froze over due to constant running of the compressor. The compressor was constantly running due to a faulty temp sensor in the fresh food side of the unit. The sensor was apparently reading too hot, thus never signalling the computer that it should stop trying to cool.
This could be what the original poster was attempting to describe.
Jul 26, 2009 | Refrigerators
Refrigerator is warm on the inside
hello mam
if the refrigerator is not cooling we should check the freezing coolant in the compressor and if necessary that should be refilled.
Jul 13, 2009 | Danby Compact Refrigerator DCR-101W
Refrigerator is freezing up inside at the top.
check the seal on the door it might be that because when the water vapor in the air gets in it will freeze on the top.
Mar 31, 2009 | GE Refrigerators
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
400 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
