Question about Ovens
I have the GE spectra XL44. The oven stopped while my wife was baking something the other day. The broiler won't turn on either. We had a similar problem about 4 years ago but I don't recall what the problem was or what the part was that was replaced. If you could assist me in Dx. and help me order the part and part number so I may replace it myself would be great. Thank you very much.
  • raymerrill5 Aug 25, 2010
    I took your advice and ordered the new ignitor and put in it. The broiler will come on now but not the oven. I have checked and double checked the wires. I was almost positive that both the oven and broiler neither one would come one when I sought your advice. Not sure now what is going on. Could I have duel problem? Could it be the cercuit board or something in the switch or could I have gotten a bad ignitor? I would think however that if it came on with the broiler, that it is ok. It fires completely up quickly without delay. Help?
  • Ovens Master
  • 8,220 Answers
If that is a gas stove which I believe it is then the most likely suspect is gonna be the ignitor. They get weak and won't draw enough amps to open the safety.A clamp on meter will confirm the ignitor is weak. It should draw 3.3 amps. I have included a couple videos that explain theory of operation and your stoves service manual. You need not bother with any gas carrying parts when making the repair.
The new part GE Ignitor WB13K0004
Hopefully this will save you some money.
More here
XL 44 Service Manual
Posted on Aug 19, 2010
  • 3 more comments
  • Dan Webster
    Dan Webster Aug 19, 2010
    You might can get this dude on ebay
  • Dan Webster
    Rate it or hate it. LOL
  • Dan Webster
    Dan Webster Aug 26, 2010
    You have 2 ignitors one for broil and one for bake.
  • Dan Webster
    Both ignitors are the same. before you spend any money swap em out and see if the oven works but not the broil.
  • Dan Webster
    Dan Webster Aug 28, 2010
    This show approximately where that bake ignitor is mounted:
Can you replace the broiler ignitor with the oven ignitor for a ge spectra
Yes very commonly the same igniter that is used fro the bake is also the same one used fro the broil as well and as loong as the igniter looks the same it should work just fine.
GENE
Sep 18, 2011 | Ovens
I have an XL44 GE Spectra Oven/range. The cleaning feature no longer works and recently we have experienced the oven not getting to the desired temp for both Bake and Convection Bake. We set it to 350 and...
Page 22
Of the service manual shows your diagram. The oven sensor should read 1100 ohms @room temp (75f) All these new fangled electronically controlled ovens use a sensor. The negative temp coefficient sensor relays back changes in resistance whenever the temp changes inside the oven. If that sensor is not correct, open, or shorted to frame then the control will not function properly.
More here
Aug 23, 2011 | Ovens
Hi Ya, I have a GE XL44 the oven and broiler won't go on. Without having a meter to check the amps how safe to assume is it that I need to replace the igniter? Could this also be a fuse? I don't...
If your lucky you may have the same exact ignitor in the bake and broil section. If so you might want to switch them just to see if it works. Hope this is helpful.
May 13, 2011 | Ovens
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
Oven not working
hey, turn the oven on and see if you see an orange glow at the bottom. this would be your glow coil. exactly like the broil. if you do, take an amp probe and check the amp draw to it. it should be over 2.9 amps. if no glow or low amps replace and start baking. enjoy
May 17, 2009 | GE JGRP17 Gas Single Oven
Bake ignitor Location
ok jimmy not as bad as you think you access it through the oven cavity remove all the racks look for two screws on the bottom panel i believe they are at the front remove them then remove the bottom panel next you will see a lame spreader which is an angled plate remove it then you will see the burner bar at the back is the ignighter just match it with the new one
Feb 11, 2009 | GE Ovens
GE XL44 oven not working, but the broiler is...???
CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
Jan 28, 2009 | GE JGRP17 Gas Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
113 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
