Cuando presiono algo dice hold junto con un candado
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE: no pasa nada
tienes i tunes en tu pc????
Posted on Jul 26, 2008
SOURCE: Magnavox 2GB MP3 Player, MSA2025/37
I just had the same problem. Here's what I did. Un-install the Device manger and then go to this websight:
http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=MP3_PLAYERS_CA&sct=FLASH_AUDIO_PLAYERS_SU&grp=PORTABLE_ENTERTAINMENT_GR&session=20081017190716_24.225.21.9&ctn=MSA2025/37&mid=Link_Software&hlt=Link_Software
Now download Device/Firmware Manager, Version: 0101001006 English (US) and instill it. Then download Firmware Upgrade - Software, Version: 002.022.005 English (US) and run it. Now open the Device manger and click the repair tab. Now hold the back button on the mp3 player and plug it in to the computer until the computer screen says that it has reported an error. Now click repare. This worked for mine I hope it works for yours.
Posted on Oct 17, 2008
  • 4 Answers
SOURCE: its frozemy mp3
me gusta old el paso
Posted on Dec 06, 2008
Fixe_You
  • 1800 Answers
SOURCE: en la pantalla se presenta un error fyle system corrupted
la tarjeta madre de tu device is coruppta .
Posted on Jan 26, 2009
Como desbloqueo mi ipod a1285 me pide un codigo de 4 dijitos y no lo se
no se que hacer porque mi Ipod model a1285 se me bloqueo le di y en la pantalla se me puso un candado y me pide codigo ke no tengo ke hago porfavor?
Mar 01, 2011 | Apple iPod nano
Tracks/streaml5ra.bun cuando esta instalando tira un mensaje que dice algo de file
cuando instalo need for speed me sale un mensage dise
1,1,TRACKS\STREAML5RA.BUN
Sep 25, 2010 | EA - Electronic Arts Need For Speed:...
A FRENHAVE KEN WOOD DDX7017 IN I KENT SEE DVD ONLY HEAR DEN,I WA
puedes entrar a kenwoodusa.com y bajar el manual de instalacion.
ahora,si no se ve el dvd es posible que no hayas conectado el cable Verde que esta el la ploga de 8 pins.necesitas conectarlo a tierra o mejor dicho,junto con el cable Negro.
Tambien hay un switch enfrente,hacia la izqierda en la esquina de abajo que dice V.SEL tambien necesitas presionar ese switch para cambiar el video.
espero que esta informacion te sirva y espero que me lo hagas saber.
gracias y suerte
Jan 14, 2009 | Kenwood DDX7017 Car DVD Player
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
Televisor
Decime el modelo de televisor (numero)
Un detalle tonto no pero Fijate que los parlantes no esten en MUTE
Acordate que el TV debe ir en canal 3 (ponelo a mano desde el TV)
Cuando tengas imagen, TODO A MANO prende y apaga la caja digital
Tambien apreta en el DVD o VCR la tecla TV/Video
Prende y Apaga tu DVD/VCR en esa misma operacion
Que pasa si pones una pelicula? No se escucha pero se ve?
Chequea el sonido desde el menu de tu tv, fijate sino hay un boton que dice MUTE
Oct 19, 2008 | Car Audio & Video
Magnavox 2GB MP3 Player, MSA2025/37 quit working. We bought 5 for our kids. All but one still comes up with "Magnavox" word then nothing. Plug into our Dell Inspiron, recognizes but then says...
Sep 15, 2008 | Audio Players & Recorders
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
22 people viewed this question
 Grubhead
Grubhead
