Question about Jenn-Air JCD2389G Side by Side Refrigerator
My JenAire model JCD2389GES side by side has slowly stopped making ice. Ice pieces accumulate on the blades that flip ice out and not getting solid ice cubes. Refrigerator side Filter changed but doesn't really help.
  • Jenn-Air Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Aug 19, 2010
Stop making ice, no water coming in, but water is available to drink
There should be a piece of metal that I believe you flip down and it will then begin to make ice.
Nov 11, 2013 | KitchenAid KSSC42QM Side by Side...
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
Amana SXD27Q2E side by side fridge....icemaker stopped making ice a couple of days ago. Seems that there is ice in the tray, but maybe it is not freezing hard enough for the ejector blades to push it out?...
There is ice blocking the assy. You need to get in there and clean it out. You WILL find a piece of ice that is blocking the assembly from turning. Happens more often than you think. Be careful when you get the piece out the blades will revolve forcefully once unhindered.
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice tray wont flip
check the very back of the ice maker and see if the piece that holds the rear portion of the ice maker has broken into little pieces causing the tray not to flip. the piece costs around 12 dollars and should be available for the unit that you are talking about. Thanks for using FIxYa and please don't forget to rate the solutions when thru please. Tahks again and have a great 2009!
Dec 27, 2008 | Samsung RS2630SH Side by Side Refrigerator
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Mar 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
276 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
