Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Drive wheels are not turning, there is power to the pump
  • 640 Answers
With the simple construction of the pool cleaners, usually a lack of movement means that there is something jammed in the impeller or the drive system. Check for obstructions in the wheels, axles, etc. and make sure that your debris chamber is clear.
Posted on Oct 08, 2010
Steering wheels makes vibration noise when turning wheel while in park
I'm thinking your power steering rack needs servicing! may be air in the hydraulic lines. did it start right after you replaced the pump? did you run the fluid resivour dry by any chance?
Jun 15, 2014 | 2002 Dodge Grand Caravan
My steering wheel locked up all of a sudden when I was driving and now it is incredibly hard to turn the wheel. I can still turn it on and off so I don't think it is just the ignition. I have a 2001...
Check that the belt that drives the power steering pump hasn't broke, then check the fluid level in the power steering resevoir, If all is okay then most likely the power steering pump has failed.
Aug 08, 2011 | 2004 Ford Focus
Power steering pump replaced, start to work ok, after 10 milles driving, steering wheel is hard, like pump is not working, under hood everything look ok.
YOU HAVE AIR IN THE POWER STEERING SYSTEM.YOU NEED TO BLEED POWER STEERING PUMP FIRST BEFORE DRIVING VECHICLE.CHECK POWER STEERING FLUID LEVEL ADD MORE POWER STEERING UNTIL REACH FULL COLD MARK..RAISE VECHICLE FRONT WHEELS OFF THE GROUND.START ENGINE LET IT IDLE WHILE TURNING STEERING WHEEL LEFT TO RIGHT NON STOP DONT LOCK OR STOP STEERING WHEEL KEEP TURNING IT SEVERAL TIMES CHECK POWER STEERING FLUID IF LOW ADD UNTIL YOU GET COLD MARK ON DIP STICK DONT OVER FILL POWER STEERING PUMP BLOW A SEAL.IF POWER STEERING FLUID LOOK TAN COLOR SYSTEM FULL OF AIR.TURN OFF IGNITION LET CAR SET FOR A WHILE CHECK FLUID LEVEL.IF STEERING WHEEL FEEL STIFF HARD TURNING DONT DRIVE CAR UNTIL YOU HAVE NORMAL STEERING.IF STILL HAVE AIR IN SYSTEM BLEED SYSTEM UNTIL AIR IS OUT.
Feb 25, 2011 | 2002 Chevrolet Avalanche
How to replace power steering pump impala 2000,engine 3.4
1. Place a drain pan under the vehicle.
2. Remove the accessory drive belt from the power steering pump pulley. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L.
3. Raise and support the vehicle. Refer to Vehicle Lifting.
4. Remove the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
5. Remove the power steering pressure line from the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L)
6. Remove the power steering return hose from the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Remove the power steering pump mounting bolts from the power steering pump.
8. Remove the power steering pump assembly.
9. Remove the power steering pump pulley from the power steering pump. Refer to Power Steering Pulley Replacement.
10. Remove the power steering pump reservoir from the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump. Refer to Power Steering Reservoir Replacement - Off Vehicle (CB Series).
2. Install the power steering pump pulley to the power steering pump. Refer to Power Steering Pulley Replacement.
3. Position the power steering pump assembly to the engine. Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts. Tighten the power steering pump mounting bolts to 34 Nm (25 ft. lbs.).
5. Install the power steering pressure line to the power steering pump. Refer to Power Steering Pressure Hose Replacement (3.8 L) or Power Steering Pressure Hose Replacement (3.4 L).
6. Install the power steering return hose to the power steering pump. Refer to Power Steering Return Hose Replacement (3.4 L) or Power Steering Return Hose Replacement (3.8 L)
7. Install the tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
8. Lower the vehicle.
9. Install the accessory drive belt. Refer to Drive Belt Replacement in Engine Mechanical-3.8 L
10. Fill the power steering system. Refer to Refilling the Power Steering System.
11. Bleed the power steering system. Refer to Bleeding the Power Steering System.
12. Inspect the power steering system for leaks. Refer to Steering and Suspension Leaks.
13. Remove the drain pan from under the vehicle.
You may want to take it to the dealer or other repair shop. It is very difficult and will consume a major portion of your day.
Nov 28, 2010 | Car Audio & Video
2006 2 wd grand vitara. I went to the store and when i came out i tried to reverse my suv but the steering wheel hardly turns and the suv makes a screeching noise. The wheels refuse to turn. I can drive...
the belt will make a screeching noise for the power steering if it is loose or worn out. check out the belt, or the power steering pump front bearings failed and will not let steering pump to spin. have a good day !!
Nov 15, 2010 | 2004 Suzuki Verona
Changeing a power steering pump
CHANGING POWER STEERING PUMP YOU HAVE TO PLACE A DRAIN PAN UNDER THE VECHICLE. SIPHON OUT POWER STEERING FLUID WITH A SIPHONER DONT USE YOUR MOUTH TO SIPHON SWALLOWING POWER STEERING FLUID CAN BE FATAL MAKE YOU SICK.WHEN ALL POWER STEERING FLUID IS REMOVED FROM POWER STEERING PUMP.REMOVE DRIVE BELT.THEN REMOVE THE POWER STEERING PUMP.THEN YOU HAVE TO REMOVE THE POWER STEERING PUMP PULLEY THE NEW POWER STEERING PUMP DONT HAVE A PULLEY YOU HAVE TO HAVE REMOVE PULLEY FROM THE OLD POWER STEERING PUMP.YOU NEED A PUMP PULLEY REMOVER AND A PULLEY INSTALLER.YOU CAN TAKE OLD POWER STEERING PUMP AND NEW POWER STEERING PUMP TO A MACHINE SHOP.THEY WILL REMOVE PULLEY OFF OLD PUMP PRESS IT ON NEW POWER STEERING PUMP.THAT WOULD BE CHEAPER THAN BUYING THE PULLER AND INSTALLER.GO TO AUTO PARTS STORE BUY NEW HIGH PRESSURE LINE O RING GOES TO PRESSURE LINE GOING INTO POWER STEERING PUMP.ONCE YOU GET NEW PUMP READY PULLEY BEEN PRESSED ON.TAKE POWER STEERING PUMP HOME PUT IT ON. BLEED POWER STEERING SYSTEM.WHAT YOU DO WHEN YOU GET NEW PUMP INSTALLED HIGH PRESSURE LINE IN PLACE.PUMP BOLTED IN DRIVE BELT ON POUR POWER STEERING FLUID IN POWER STEERING PUMP UNTIL FLUID LEVEL STOP DROPPING AND YOUR LEVEL ON POWER STEERING DIP STICK AT COLD LEVEL.NOW START CAR UP LET IT IDLE FOR 3 MINUTES.THEN TURN OFF ENGINE CHECK POWER STEERING FLUID IF FLUID LEVEL DROP ADD LITTLE MORE UNTIL LEVEL ON DIP STICK ON COLD MARK DONT OVER FILL.NOW SAFELY RAISE SUPPORT FRONT OF VECHICLE. START THE ENGINE.TURN STEERING WHEEL FROM ALL THE WAY FROM LEFT TO RIGHT DONT STOP LOCK WHEEL .GO LEFT TO RIGHT SEVERAL TIMES.THEN TURN OFF ENGINE CHECK FLUID LEVEL.IF ALL IS GOOD LET VECHICLE BACK DOWN LET IT SIT FOR A WHILE CHECK FLUID AGAIN.DONT DRIVE VECHICLE IF POWER STEERING PUMP MAKE NOISES OR YOUR STEERING FEEL STIFF HARD TO TURN.JUST MAKE SURE FLUID LEVEL RIGHT AND DRIVE BELT TIGHT GOOD LUCK.
Nov 02, 2010 | 1999 Oldsmobile Alero
When turning into a parking spot, all of a sudden my steering wheel seemed as though it "Locked Up".. not as it would if the car was shut off, but like I lost power steering. A light came on on the dash. I...
It is most likely you just turned the wheel to the farthest limit of its travel, and the power assist cutout at that point.
Check your fluid level to make sure its up to where it should be.
If fluid is fine, I wouldn't worry about it...it is fine and a normal occurance.
Sep 30, 2009 | 2005 Pontiac G6
I was driving and my 94 mits expo made a loud screetching sound and my steering wheel locked up i can barley turn my steering wheel people that have looked at my car say it's the water pump what would that...
the belt that drives the water pump also drives the power stearing pump and it was locked up and not allowing it to spin fast enough for it to work or the belt broke
Jul 20, 2009 | 1994 Mitsubishi Expo
Makes a noise when i drive and gets louder when i turn the wheel. i think its low power steering fluid. the wheel is harder to turn now.
Check the fluid, if it's low put some in it, if it still does it, the power steering pump might be on it's way out.
Jul 16, 2009 | 1990 Ford LTD Crown Victoria
Steering system
It very possible that the new power steering pump is defective. I would take it back for a possible warranty issue.
I'm confused about the part where the water pump damaged the power steering pump. The power steering pump doesn't require any cooling from the water pump. The power steering pump only needs the belt to run it properly.
May 21, 2009 | 1995 Toyota Camry
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
57 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
