Question about E-Machines W3107 (RBW3107) PC Desktop
I would like to add ram, do you know how many slots and how much memory I can add to this computer? Thanks, Cyn
    President:
  • 2,571 Answers
Your pc takes DDR2 400 also known as PC 3200 , you can have a max 2 GB and you have 2 slots. It had 1 stick of 512mb when new.
From amazon or ebay, expect to pay about £40 for 2 x 1GB sticks (2GB set)
Posted on Aug 19, 2010
  • 4,737 Answers
Your machine supports, DDR2 SDRAM or (DDR2) type Ram, maximum 2GB and has two Ram Slots.
Good luck.
Thanks for using FixYa.
HOW dO I aDD memory?
It really depends on what you have now. Go to crucial's site http://uk.crucial.com/gbr/en/ and use the scan computer tool and it will tell you how, if you can and the parts if possible.
Frankly this is the safest and surest way of doing this.
Sep 13, 2014 | Dell OptiPlex GX520 PC Desktop
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
The board for this appears to have a dead ram slot.If putting ram into second slot the monitor just goes black with line distortions.Remove the Ram and install to first slot everything works ok add a 2nd...
Inspect the memory slot carefully. If there are are bent pins in the slot , you can probably align them with a pointed tip. Otherwise the best option would to replace the motherboard. Because after the process RAM is the fastest component in the computer. Out of experience in repairing the motherboards ,i recommend to replace the motherboard.
Thanks Fixya
Proton
Jun 17, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
How do I add memory to my dell desk top?
After determining that you can add RAM and have obtained the correct RAM follow these steps.
Step 1: Power down your laptop. Unplug the power cord and remove the battery.
Step 2: Use an ESD wrist strap or other method to ground yourself. This is important to prevent static electricity from damaging your computer.
Step 3: Check the user manual or service manual for the location of the Memory Access door. On most Dell laptops, it is located on the bottom of your computer.
Step 4: Open the memory access door by removing the two small screws that hold the door in place.
Step 5: Use your fingertips to gently spread the securing clips at either side of the memory module until it pops up.
Step 6: Remove the RAM module from the connector by sliding it backwards from the slot at a 45-degree angle.
Step 7: Align the notch in the bottom of the RAM module with the tab in the connector slot.
Step 8: Slide the module firmly into the slot at a 45-degree angle.
Step 9: Rotate the module downward until the securing clips click into place.
Step 10: Replace the memory access door.
Step 11: Replace the battery and power up the computer to be sure that the RAM is recognized.
Sep 25, 2009 | Toshiba Satellite A100-S8111TD Notebook
I have a dell b110 dimension...i took the memory out to see what kind of ram it was to add more to the system. When i replaced the ram, it wont boot up. when you push the power button, it hums like it is...
Check first if the memory is loose or there are any parts that have come loose such us IDE or SATA cables, For errors you should also get warning sounds.
Sep 07, 2009 | Dell Dimension™ B110 PC Desktop
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Inspiron 6400 notebook
    There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
    The cover ont he bottom if the laptop is easy to access and add more memory.
    Dec 31, 2008 | Dell Inspiron 6400 Notebook
    Want to add memory to Gateway 700x
    Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
    You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
    Dec 08, 2008 | Computers & Internet
    Zlatko
    Your laptop can have up to 1 GB of memory. You should have two slots and you can install 512 MB per slot. Your laptop is using 200 Pin DDR PC2100 266 MHz CL 2.5 SODIMM. You can also install PC3200, but your laptop will clock it down to 266 MHz.
    Regards,
    Feb 27, 2008 | ASUS A2H (A2HOB) Barebone
    E-Machines W3107 (RBW3107) PC Desktop Logo
    77 people viewed this question
    Top E-Machines Computers & Internet Experts
    Matthew Spark
    Matthew Spark
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
