Question about Olevia LT32HVE 32 in. LCD Television
Blue lcd light in from is pulsing and tv wont go on untill i unplug it and leave it for a few mins then plug it back in this problem happens alot
  • Olevia Master
  • 5,568 Answers
From the symptoms you describe, I suspect the main power supply is in the process of failing. Certain components contain chemicals that decay over time reducing the value of the part and if they were made by a poor manufacturer and are used in circuits designed to supply 'feedback' to regulate it, they eventually fail and this normally shows up in a reluctance to start up as they should rather than just dying while running.
You may be aware that Olevia (Syntax) is bankrupt but there seem to be a number of service possibilities but don't know what might be close to you so just run a search with terms Olevia and repair or support.
I also own an Olevia but will likely be able to repair it when it goes down.
Posted on Aug 19, 2010
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
I purchased a Vizio 32' VA320M off of ebay and it arrived today, I hooked it up watched it for a couple hours this morning, played a little xbox on it and went to sleep. I woke up tonight and was...
This tv have the main Tuner signal board have intermitten problems.Return this tv for a refund.Can't return it make a claim with Ebay,Pay PAL or ur credit card if pay by credit cards.
May 12, 2011 | Vizio L32 32 in. LCD HDTV
My tv wont turn on i have a toshiba regza. when i do turn it on the red light in the front blinks every few secs over and over for as long as its plugged it. i tried a few things but still no solution....
The first thing to try is to unplug the TV, leave it unplugged for about 60 sec, the plug it back in. If the problem persists, this is most likely an issue that will need to be resolved by an electronic repair store/facility.
May 06, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Wharfedale 42f1080p faulting?
Replaced any swolen capacitors on the power board.
Sep 01, 2009 | Televison & Video
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Tv going off radum
Go to www.kb.sony.com. Look up user manuel. It sounds like the timer is turned on. Mine is duing the same thing but a little different. They tell me to unplug from powere surge protector and leave unpluged for awhile then plug into wall. I am waiting right now so we will see what happens. Make sure you have your model number before going on the site.
Jan 15, 2009 | Sony KDF-E55A20 55 in. LCD Television
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
Olevia LT32HVE 32 in. LCD Television Logo
65 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
