Question about GE Microwave Ovens
My built in microwave door handle broke (well, doesn"t latch without slamming the top part) is ther a way to fix this without having to replace it?
  • GE Master
  • 9,098 Answers
You have to separate the door panels (as shown in the attached photo) to get to the internal door parts.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order door parts by entering your full model number here.
Posted on Aug 20, 2010
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Door will not close without slamming
Possible causes - door switch, or door switch assembly out of adjustment; plastic latch guides on door switches worn; door hinge worn, causing door to be out of alignment. If it's the last one, the unit needs to be checked for microwave radiation.
Dec 22, 2013 | Panasonic Inverter Countertop Microwave
The door doesn't open
please follow the instruction and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
May 28, 2013 | Cuisinart Microwave Ovens
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
I have an Oster DLC-7 food processor. It has always been very hard to close requiring force. The last time I used it, a white plastic part popped off from the back. I don't know whether anything is...
You have a broken the door latch.Most people have the habit of slamming the door shut ( the same way some people hit the enter button on the computer ).With age the plastic becomes brittle and the slamming accelerates its demise. Now connected to this latch is a safety feature which shuts down the Microwave when the door is opened during cooking. So till you replace this latch the microwave will not work. Disconnect the microwave from the power outlet and remove the top cover ( 4 to 5 screws at the back ) , look near the bottom close to the DOOR OPEN button.You will see the rest of the latch with a spring attached to it.Do not attempt to glue the broken piece because the force exerted on the latch is very high and will not hold. You challenge is getting a replacement. Best would be to contact the seller or locate a authorized service center from where you might be able to procure it. It should cost you about 5$.
Aug 22, 2011 | Microwave Ovens
Microwave not heating
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
Handle Replacement on a HKMS155L Microwave
I think you have solved your problem already.
I have seen your requesty only now and I am sending the diagram to replace handle.
You remove door latch (nr 3 on diagram) first, then you unscrew the screw nr .8 and remove handle (nr.7).
Below the diagram:
You can find all parts and diagram for your appliance here.
Jun 09, 2008 | KitchenAid KHMS155L Microwave Oven
Panasonic s550bf Door Latch
Do you still have the piece that broke off? If so, you may be able to use two part epoxy to glue it back in place. I did this with a colaric MW and it did the trick. The latch was hook shaped and made from a hard plastic. Pete
Sep 02, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
44 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
