Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Drive wheels are not turning, everything else seems ok
  • sull744 Aug 19, 2010
    the impeller is clear of debris and turning freely and the wheels are free of debris also. wheels still do not turn?
  • 10,515 Answers
Most of the time with these automatic pool cleaners, that is going to be the impeller. Check your impeller to make sure that it does not have debris that is clogging/jamming it. Also, check the front and rear wheel axles for debris. Leaves and other large items often get stuck and prevent proper function.
Good Luck!!
Thanks!!
Posted on Aug 19, 2010
  • taran_2005
    taran_2005 Aug 19, 2010
    Thanks for your response!!
    As you have already checked, most likely a loose wire is touching metal somewhere inside your unit.
    You may consider replacing the power unit because it might be cheaper
    then repairing it. Or have a technician to take a look to the internal
    wiring since it is a bit tricky.
    Good Luck!!
    Thanks!!
  • 2,382 Answers
Hi, most of the time with these automatic pool cleaners, that is going to be the impeller. Check your impeller to make sure that it does not have debris that is clogging/jamming it. Also, check the front and rear wheel axles for debris. Leaves and other large items often get stuck and prevent proper function.
My89 dodge dakotas steering is copletely loose and wheels dont turn at all everything seems to be attached,whats the problem
where to start? any steering fluid? steering belt ok? steering wheel tight? steering pump ok? front end pitman and idler arm(s) ok? front end bushings or rod ends ok? steering box gears steipped? steering rack could be stripped. check all these first then get back to me.
Jun 05, 2016 | Dodge Cars & Trucks
My Mercedes clk 230 komp has an issue withe the front passenger wheel. when pulling away on full lock right, its like the tyre is running on flat and it starts to knock. everything seems ok wheel bearing...
wheel bearings should have no play at all The correct adjustment is no preload -no end float with the adjustment nut moved slightly to preload to fit the pin.
It is happening on full lock ,check the full lock stop as the tyre may be hitting on the suspension or inner guard.
Feb 18, 2015 | 2001 Mercedes-Benz CLK-Class
2000 ford f250, four wheel switch locked in in cab, no front wheel drive, lock in both front wheel hubs and now have 4 wheel drive. Flip off switch inside and no longer in 4 wheel drive.
I really don't know quite how to tell you this. Everything seems to be working just fine buy your question. When your using 4 wheel drive, you engage the hubs first, then push the 4 wheel drive button or turn the switch. Ease it in and out of gear or shift on the move and you should be in 4 wheel drive at this point. To take it out of 4 wheel drive, reverse this procedure. Turn the switch off and ease forward and you will be out of 4 wheel drive. If your not going to use your 4x4, turn the hubs out to reduce ware on the axles. If you will be using 4x4 again soon, leave the hubs in and all you have to do is turn the switch to 4x4 and your set to go. I hope I explained this well enough. Good luck.
Feb 10, 2015 | Ford Cars & Trucks
Had one 1993 jimmy, bearing ate into shaft. have a parts jimmy bought same model, color, everthing seems the same. when i went to change the differential the two were different. as long as i take out the...
I see a red flag here. If they don't look the same, they may have different gear ratios. This is critical in a 4 wheel drive. Front and rear gears have to match
Mar 19, 2011 | 1993 GMC Jimmy
I have a 03 Jeep Liberty - whether I'm pulling in or out of a parking spaced and turning the wheels, it feels as if something is grabbing or rubbing against the front wheels. Making u-turns is extremely...
it is difficult to make sharp turns while in 4 wheel drive on a hard surface. If you are able to make sharp turn easily in 2 wheel drive then everything is probably OK. Check your owners manual and review the 4 wheel drive section, there is much to learn.
Oct 20, 2010 | Jeep Liberty Cars & Trucks
I have a focus st3 2006 up to 30 mph i det a droning noise like a worn wheel bearing had the car checked out and wheel bearings seem ok could it be a dry bearing?
No, its your axle drive or cv booth are the problem. Check your cv rubber booth if rip, check both side wheel. Rubber booth is a sealed rubber covering the cv joint of your wheel. Sometimes you feel and you will hear that noise, only when you make a turn. Replace your both front wheel drive axle, ok
Mar 14, 2010 | 2006 Ford Focus
Rear end thumping noise
Depending on the year of your gto it could be a buggered CV joint on one of your back wheels. All GTO/3000GT are four wheel drive but up to the mid to late 90's they had four wheel steering. The usual symptoms of a buggered CV joint are loud rattling and/or vibrating from the affected wheel at around 30 - 40 mph and often a loud clunk when cornering at low speed
Aug 12, 2008 | 1991 Mitsubishi 3000GT
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
55 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
