Question about Copystar CS-2030 Copier
Intermittent paper jams after fixer just before exit.
  • dan_brandon Aug 19, 2010
    I found the problem. A small solenoid that moved some guide fingers right after the fixer would occasionally stick in the out position. Replacing a tired spring that pulled it back fixed it. I knew the rollers were working well because the paper was pushed by the last set of rollers into an accordion fold.
    Brigadier General:
  • 5,158 Answers
Recheck the manual. it may be that you are using the incorrect thickness of paper for that machine
Posted on Aug 20, 2010
    Genius:
  • 1,478 Answers
Among the most common problems with any make of printer are paper jams. A printer will jam for any number of reasons: It’s dirty, the wrong paper type is being used, or the rollers on the printer that feed the paper through its pathway are worn down. While cleaning the printer periodically and using the correct paper type are easy fixes, but if all this are in place and paper still jam, roller replacement is the next alternative because when rollers are worn out, it causes Intermittent paper jams on printer.
I will suggest you replace the roller on the printer to fix the problem.
Take care.
Posted on Aug 19, 2010
Toshiba e 255 is error code E 030
E030 indicates jam on exit...It is intermittent jam or totally jam?
U need to check the paper transport from feeder to registration then up to fuser unit, lastly exit unit...
Sep 01, 2015 | Toshiba Office Equipment & Supplies
My copier canon ir2525 legal size paper jamming problem half paper exit unit out half paper exit assembly in A4 size and A3size 100%perfect exit plz solution this problem
Most common jam problems are caused by using thin paper 80g density or less. Recycled paper is the worst as it tends to tear easier as the their is only 20% new cellulose fibre in it and 80& is paper mache'. When using recycled paper, use min 100-120g weight papers and your jams will disappear.
May 29, 2015 | Canon Office Equipment & Supplies
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
Why does the paper come out wrinkled from HP Laser jet 3030
Problem: Paper jams as it exits printer, starts out as intermittent and gets progressively worse. Paper has accordion folds at bottom.
Cause: Fuser drives paper out faster than the worn out exit rollers can push it out of the printer. This causes the paper to fold up.
Solution: The rubber treads in the rollers wears down, making them smooth. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable. If problems persist, the rollers need to be replaced.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | HP Office Equipment & Supplies
Mp600 paper ouput slot error will not reset
canon printer is telling me that i have paper jammed in paper out slot when ther is no paper in it can it be reset? or is it not fixerable by my self.
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
What about you open the back of your printer & tighten it
Apr 17, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
CANNON PC745 SAYS PAPER JAM. NO PAPER JAMMED.
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Brighton2m
Apr 16, 2010 | Canon Office Equipment & Supplies
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
Copystar CS-2030 Copier Logo
55 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
