Question about Dell Inspiron 6000 Notebook
My card reader will not read my SD card with pictures from my camera; I get an error message that says the storage card was not found. I tried 2 different cards and it was the same with both.
latinmcgyver
  • 208 Answers
SOURCE: sd card reader does not work
you might need to remove upper and lower filtrs with filtercheck 4.6
then repair sonic dla (if it has sonic burning software you use)
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Posted on Aug 20, 2008
Felinna
  • 42 Answers
SOURCE: Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Posted on Feb 23, 2009
e-Guru
  • 3917 Answers
SOURCE: SD card reader not recognizing card
the original file (apparently version 2.0) is here:
http://64.233.161.104/search?q=cache:2288as3q0skJ:www.asus.it/support/download/selectftp.aspx%3Fl1_id%3D3%26l2_id%3D45%26l3_id%3D0%26m_id%3D1%26f_name%3DCardReader_050118.zip~zaqwedc+CardReader_050118.zip&hl=en
the updated driver (version 2.3) is located here:
http://support.asus.com/download/download.aspx?modelname=V6V&SLanguage=de-de
scroll down to where you see RICOH card reader driver
or more specifically this link here:
http://dlsvr03.asus.com/pub/ASUS/nb/V6V/CardReader_XP_2K_050808.zip
even though the site is primarily in german, all the component names are in english, go figure. So it would seem that the asus comp manufacturer are a little more forthcoming than dell in this particular instance. for example, nowhere on my component sheet does it say that RICOH is the manufacturer for the card reader, that's something i got from you guys on the forums
anyway, after installing this driver and rebooting my comp, card reader immediately recognized both MMC and SD media. unfortunately, it was only able to access the mmc card, and i'll be shipping my comp off to dell for whatever motherboard replacement they're willing to give me (which i don't mind, so long as it works when it comes back to me) but i thought these links might be helpful for others who are having the same problem.
Posted on Mar 19, 2009
  • 489 Answers
SOURCE: my SD card reader isn't reading the memory cards
The card reader slot(s) appear as drives under Windows Explorer. It is accessed just like any other disk in the system.
Posted on Apr 07, 2009
benwabnick
  • 2404 Answers
SOURCE: Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
Posted on Jun 04, 2009
My computer quit reading the card or the camera, so I can't get pictures from the camera onto my computer
Try removing theSD memory card from your camera and inserting the SD memory card into an USBmemory card reader then connect the USB card reader into the USB port of aworking computer. The computer will see this USB card reader and SD memory cardas an external storage device. You can open the camera photo folder and copythe photos to your computer.
Apr 13, 2012 | Nikon Coolpix S4000 Digital Camera
Tip
How to Recover Pictures From Fujifilm FinePix S700 Storage Media
With 7 mega pixel camera, 10x optical zoom, 2.5 LCD, picture stabilization mode, and i-Flash intelligent Flash, the Fujifilm FinePix S700 fulfills all the requirements of any photographer. The storage media (SD and xD memory cards) used in this camera allows the photographer to save audios, videos, and photos of different sizes. Damage in storage media can occur any time, resulting in fatal consequences, like inaccessibility of data saved in the memory card. In most cases, the photographer encounters an error message stating that the card is corrupted. To overcome such corruption scenarios, the photographer needs to restore the data from an updated backup. But all photographers do not create a backup on regular basis. For them, a third-party Camera recovery software acts as a boon and helps them recover the data.
As a real-world instance, you encounter the below error message while trying to view the pictures saved in your SD card (inserted in Fujifilm FinePix S700):
"CARD ERROR"
After the above error message pops up, the data saved in the SD card becomes inaccessible.
Cause:
Few main causes for the above error message are:
1.Incorrect SD card format.
2.Incompatible SD card.
3.Memory card corruption due to unexpected camera shutdown, virus infection, and interrupted read or write operation.
Resolution:
To resolve the above error message and to access the data saved in SD card, you will need to:
1.Use a compatible SD card.
2.In case of memory card corruption, format the card in Fujifilm FinePix S700 camera. Though formatting brings the card in reusable state, all the audio, video, and picture files get deleted. To recover the deleted data, you will need to choose a powerful Camera recovery software.
Such recovery tools use effective scanning methods to ensure complete Camera data recovery. These tools can be downloaded from the Internet and used by anybody. Such applications are safe as they harm the original data saved in the memory card.
Digital camera recovery software is a world-renowned Photo Recovery utility used for recovering data from almost every type of memory card. This software ensures complete recovery of digital files, irrespective of their size or type. Compatible with Windows and Mac OS X, the read only software also recovers data from other storage media, like Zip drives, hard drives, etc.
on Jun 30, 2010 | Cameras
I have an Akai DC6371 digital camera and the card I have in it is a Kodak 128mb SD card. However, the camera will only let me save 4 pics to the SD card. I tried putting a different card in it that's...
Hi I can tell that sometime you have to format within computer using external memory card reader, not from camera. It is not recommend switching around one sd card to another camera. It cause card error. If you want to use it, then you have to save pictures somewhere in other storage or computer, and format the one you want to use in computer using external memory card reader. And then one more time format in camera (you have to insert memory card into camera) These method very helpful on like your problem. If not working, then you have either camera defective or memory defective. Thanks and best regard!
May 25, 2011 | Akai DC6371 Digital Camera
I get an error message when downloading my pictures of 802a006. When Im trying to view the pictures on my camera it reads unidentified image. What can I do to save or repair these pictures?
Here is what you can try.
Don't use the camera for downloading the pictures.
Buy a card reader.. prices vary from a few $$ on Ebay (for instance) to maybe near $20.00 for the best kinds.Also many printers now come with the card readers built in. Use the card reader for downloading the pictures from your card from your camera. Since I repair a number of kinds of cameras, I use a card reader...no software needed, no drivers.
Download the pictures in a folder (preferably on C, or another drive in it's own folder, not in my documents) and then use a program to view, edit or save to cd or DVD.
A nice thing about a card reader is that with most newer operating systems the card reader will be detected as a mass storage device.
Sep 17, 2009 | Cameras
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
SD 215mb memory card reads ''memory card error''
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Nov 12, 2008 | Vivitar ViviCam 5385 Digital Camera
Communication error
If your SD memory card contains more than 1,000 images, the camera will display "Communication Error". Use a card reader (if available) to import your images into the computer, or see about having some CD's made at a photofinishing business.
May 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error message
If the pictures are on an SD card you can simply remove the card and use a card reader on your computer to copy the pictures off.
Stores will often also have picture printers that can read the SD card.
Mar 08, 2008 | Vivitar ViviCam 5385 Digital Camera
Dell Inspiron 6000 Notebook Logo
53 people viewed this question
Alun Cox
