Lexmark printer 6500 series Wireless. it was printing the first 10 times in use, then it stop printing a whole page.It prints the top line or the bottom line
  • art fer May 02, 2008
    Printer is only 2 months new
    Genius:
  • 1,447 Answers
Have you tried uninstalling and reinstalling the driver? Have you tried printing from a different application?
Posted on May 02, 2008
    Master:
  • 555 Answers
A manual for your printer, with troubleshooting instructions, can be found here.
My HP 6500 Printer jammed and now everything it prints has a line running down the side. Each segment is about 1/2 inch long and runs down the whole page.
This type of line is cause by a scratch or smudge on the toner cartridge's image drum. You will need to replace the toner cartridge.
Nov 01, 2017 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless TOP OF PAGE CUTOFF
Have you checked to see if you are printing with borders or printing borderless (under Preferences/Advanced)? I had this problem when printing double sided, since it will only be able to print double sided with borders...
Jul 11, 2012 | HP Officejet 6500 Wireless All-in-One...
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
Lexmark pro 205 printing a blank page before a document
If you're using Windows, try to follow these steps to fix the problem.
  1. Start menu > Printers & Faxes > Lexmark Pro200 Series Properties window pops up > go to Advanced tab > Printing Defaults.
  2. The Lexmark Pro200 Series Printing Preferences window pops up > go to Advanced tab > More Options > under Suppress Blank Pages, enable "Enable blank page suppression"
  3. Save the setting.
  4. Try to print a document again to verify that the problem is fixed.
Nov 09, 2011 | Lexmark Prospect Pro205 Wireless...
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
My lexmark z1420 has been in the loft for some time, I have switched it n anf the wi-fi light keeps flashing orange no green?
Try to print the wireless settings page to determine if your printer is still on the same wireless network as your router and computer. To print the page, follow the steps in these article on How to Print the Network Settings Page on the Z1400 & Z1500 Series Inkjet Printer; a brief explanation of its values. On the page, check the Status, SSID and also the IP address and see if it's connected to your network. Otherwise, you may need to reset your Lexmark Z1420's wireless network adapter and reconfigure it. To reset, follow the steps in this article on How to Reset the Z1400 and Z1500 Series Network Settings. Launch the Lexmark wireless setup utility to reconfigure the printer to your wireless network.
Hope this helps.
Jan 07, 2011 | Lexmark Z1420 Printer
Why can i not install my lexmark 6500 series to my Mac
Lexmark 6500 Series (WiFi) Mac Driver can be located and installed as a previously set up printer if you used it with another computer or OS:
http://support.lexmark.com/index?page=downloadFile&actp=CONTENT&productCode=LEXMARK_X6575&id=DR20481&segment=DOWNLOAD&userlocale=EN&locale=en&oslocale=en_US&osVendor=MACINTOSH&osCats=Mac+OS+X+10.6
Driver Download from web, same as a CD: 6500 Series Web Installer.dmg
I hope this will solve the problem. If you have a problem go to the Applications folder/ Lexmark for the wireless set up. You will need the printers print cable, USBed to your computer and follow the directions. Good luck.
Sep 30, 2010 | Lexmark International Lexmark 6500 Series
When selecting a printing task,If I ask for one copy,the machine continues to print even after hitting the cancel printing. Second*lets say there are two pages to be printed the first oage will print,the...
Hello. Try to unplug the printer from the power outlet for about 10-15 seconds to refresh itself. If that doesn't resolve the problem, it might be software communication issue. You can uninstall then reinstall the software. If you're computer is running on Windows, uninstall by going to Start Menu > Programs/All Programs > Lexmark Series folder > Tools/Uninstall. Reboot pc. Reinstall software. If your using Macintosh, go in the Lexmark folder and Uninstall. Reinstall software. Hope this helps.
Mar 17, 2010 | Lexmark C533DN InkJet Printer
I can no longer print to my Lexmark 6500.
hi.
if u dont have the cd,try the downloaded version from www.lexmark.com ..try connecting usb cable and check if printer works,,,if it does then its an issue with wireless connectivity..
good luck
Jan 25, 2009 | Lexmark Office Equipment & Supplies
62 people viewed this question
jasbo
jasbo
