Question about Whirlpool LSR5132J Top Load Washer
How do i turn prop when it gets lockedup? - Whirlpool LSR5132J Top Load Washer
How to know if engine lockedup
Remove the serpentine belt. Put a socket and breaker bar on the crank pulley bolt. Try to turn it clockwise. Doesn't move, locked up. If it does, see if it will start, then look at the A/C compressor being locked up. Best to check all the pulleys. A/C compressors will lock an engine.
Oct 19, 2016 | Cars & Trucks
Put outboard in gear and prop turns ,anything abohe idle prop doesnt keep up 30hp
with engine off put in gear and check prop fully in gear , get a friend to hold the flywheel solid and you put pressure on the prop and if you can turn it try adjusting linkage to get more selection in forward then check neuteral and reverse ok also ! check the prop bush isnt slipping also !
Sep 03, 2014 | Motorcycles
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
Suzuki outboard 8hp 1994, at higher speeds under loading prop appeared to cavitae, liek spun prop. repalced with new prop. On the bench, plugs removed, in forward gear hand turn prop thur haft turn and...
You may not be deep enough in the water and it really is cavitation.
May want to check the lower oil for metal as a Mostly worn out gear can do that
It's normal for a gearbox in forward to "click" in one direction and be firm against the motor when turning against the gears normal rotation.
Oct 10, 2012 | Light Boating
My Prop On My Larson Boat With A Mercruiser Alpha 1 Drive & A 5.7 Liter Engine Won't Turn The Prop In Forward Or Reverse. When The Engine Is Off & It Is Shifted Into Forward The Prop Can B
run the engine and watch the drive shaft behind the engine , is it turning ? also as your mate selects forwad and reverse ! does it stop turning ? pos flywheel damper or output shaft damaged ! pos gearbox damaged !??
Jun 04, 2012 | Mercury Boating
Mini kota wireless saltwater series prop will not turn
If the motor is turning and the shaft is turning and the prop is not, then you may have sheared a pin at the prop. This "pin" is a small piece of metal that is made to shear when under too much pressure so that you don't damage the motor, shaft or prop if the prop hits something that doesn't give. If you can turn the prop freely then this may be your problem.
Oct 15, 2011 | Boating
I cant seem to figure out how to take my prop off my minn kota trolling motor. there is a plastic nut and a screw in the center of it. they both just turn. ive used a screw driver to turn the screw and...
I had the same problem tonight. I wound up getting it off by appling a diagional pressure to the prop. That held the shaft screw. Then my Dad turned the wing nut with a neddle nose pliars conter clockwise and it came right off.
My problem and probably yours too is once inside there is a pin holding the prop to the shaft that was broken. I don't know how to get the new pin back in since it is inside the prop with no access from the outside.
Jul 22, 2010 | Minn Kota Endura 30 Freshwater Transom...
Not type s its a c711xbit is a unlocked phone
im not familiar with that type of phone but it will be in the profile menus with silent, loud etc
Sep 10, 2009 | Casio G''zOne Type S Cellular Phone
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
