Question about GE Refrigerators
Fridge compressor will not run? why - GE Refrigerators
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 19, 2010
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Should the fan operate all the time in my refrigerator
Most of the time it runs only when the compressor is running. In other words compressor and fans will run together when the fridge thermostat ask for cold and stops together when thermostat is satisfied. In newer fridges some time inside fan (evaporator fan) might PERIODICALLY run without compressor to circulate little cool air to fridge compartment from freezer compartment.
Sep 30, 2014 | Whirlpool Refrigerators
The temperture is at 88 the buttons are not working
Hello Rpope808,
I understand that your Refridgerator is not getting cold. I do not know if it is just the fridge or the fridge and freezer. If both are getting warm then you need to make sure the compressor is running in the back at the bottom of the fridge it will be humming. If the compressor is not running then nothing is going to get cold.
If the compressor is running then you may have a problem with your fan not running inorder to move around the cold air. Below are two tips that will help you to check both of them.
1. Compressor not Running
2. Fridge not getting cold
Thank you for choosing FixYa.com
Justinbur167
May 11, 2011 | Samsung RS2556 Side by Side Refrigerator
I have a Matsui MUL1107WW fridge and the motor appears to be cutting out when the fridge gets too cold. Is this normal ? or does the motor need looking at ?
The compressor motor only needs to run to cool the fridge down.
Once the fridge is cold enough the compressor motor will switch off.
The compressor will start again when the fridge warms up
May 02, 2011 | Refrigerators
Im having a problem with the fridge not cooling. the ice box works just fine and i have the controls on max but its not cooling down
See if the compressor is running. its under the fridge and will be humming. If its running you fridge and the fan under the fridge is running also then your fridge is low on freon. If the fan is now running replace it. If the compressor is not running it could be the starter which is inside the plastic cap on the compressor. It is a nickel size part connected to one of the 3 prongs on the compressor. It also could be the timer. The timer is a device that turns to fridge defrost. It is located behind the plastic in the top,back of the ref side of the fridge or behind the back in the freezer or under the front bottom underneath the fridge. it will have a slot near its center that a flat blade screwdriver can fit in turn it slowly and you will hear audible clicks the compressor should kick on if not its not the timer. good luck
Aug 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
GE fridge does not get cold, 60 deg in freezer 70 deg in fridge, compressor is running condensor fan is running and fan inside of fridge is working
You have either a bad compressor or a refrigerant leak.Some times a compressor runs but doesn't compress the gas.It is more likely the unit has a sealed system leak which would have to be located,repaired,and evacuated,then recharged.(not a simple task).
Jun 01, 2010 | GE Refrigerators
How can I tell if my fridge isn't working?
Unplug the Ref for 15-20 min. take off the cover so you can see the compressor, then plug it back in and listen for the compressor to start. You should be behind the Ref so you can tell the difference between the fan running or the compressor.
The compressor should start and keep running.
The fan cooling the compressor should be running.
The fan in the freezer should be running.
You should feel cold air coming into the Fridge side from the freezer side.
Jan 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
