Question about Cameras
Hello sir i have Nickon Coolpix L12 when i insert my memory card it is displaying the message that "THIS CARD IS NOT SUPPORTED" plz help !!
  • kakima Aug 19, 2010
    How big is your memory card? The L12 is designed to work with SD cards. If your card is larger than 2GB then it's actually an SDHC card. While it fits into the slot, it will not work.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having gone over a month without a response to my query, I assume it was just a SD/SDHC mismatch.
Posted on Sep 23, 2010
How do you transfer photos from Nikon Coolpix L12 camera internal memory to the memory card
by usb to your pc and then onto a memory card is probably the easiest way of doing it, unless something is preventing this course of action
May 30, 2015 | Nikon COOLPIX L12 Digital Camera
I am having nikon coolpix L18 camera, it is working with internal memory card. When i inserted external memory card, it display "this card can not be used". I checked ext memory card in another...
Your camera supports SD HC, multimediacard and SD memory cards, is that card of a different type? you will get this problem if the card is of too large capacity too, your camera ,might have an upper limit for supported memory capacities.
May 02, 2011 | Nikon COOLPIX L18 Digital Camera
Hello sir when i insert my 4gb kingston pendrive.then i will see that yyyyyyyyyyyyyyyyyyyyyy usb device.and after few minuts.the device not show in my the pc.if i update or reinstall usb wizard.hte...
Memory cards reader usually doesn't require drivers.
There's 2 possibilities here :
1. Your card reader is faulty. Try another card reader. 2. Your card itself is faulty. If it's still under warranty, try contacting Kingston.
Hope this helps.
Feb 28, 2011 | Kingston 4GB Secure Digital High Capacity...
How do I delete the pictures from my Nikon coolpix880 camera
Use this option to format the internal memory or memory card. Formatting the Internal Memory To format the internal memory, remove the memory card from the camera. The [Format memory] option appears in the setup menu.
Formatting the Memory Card
When the memory card is inserted in the camera, the [Format card] option appears in the setup menu.
or for more detail get the user manual from here
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
do rate the solution if helped
Nov 28, 2010 | Nikon COOLPIX L12 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Mar 19, 2009 | HTC S710 Smartphone
Plz help me
hello... your problem suggests that your memory card is corrupted and i dont think u can recover a corrupted memory card. buy a new one n try not to inserting/removing a memory card carelessly n frequently. its better to format your working memory card through ur mobile phone than wid pc software but if it struck then try to use card reader n format it through ur pc just like any other removable disk drive n for Nokia N72 the memory card's file system is only FAT and not FAT32.
Jul 26, 2008 | Nokia N72 Cellular Phone
Memory card is not accessible in N70 MUSIC EDITION
buy a new one .but next time when u want to format ,connect to pc suite via pc and then select memory card and delete file by file but never delete an instal program otherwise it will be corrupt again.so if u want to delete instal promgram ,go to tool / application manager and delete it from here.
Feb 21, 2008 | Nokia N70 Cellular Phone
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
