Question about Denon AVR-2106 Receiver
My AVR-2106 receiver will only stay on for a few seconds before clicking off. We have disconnected all components and speakers from unit to eliminate short circuit/wire problems and still with only power source plugged in, unit clicks off after a few seconds. Should I try to get it repaired or replace with a new unit of comparable capacity? Finding a place near me to get it repaired is proving difficult. Thanks very much for your honest opinion. I await your reply. Amy
  • Denon Master
  • 17,130 Answers
Hi amy, Your vivid description of the problem confirms that the protect circuit is cutting off the amp on detection of a high current drain. The possible fault is the failure of the Audio Power Output Mosfets. You will need to remove the mother board to test the stage and confirm to replace one of the stages.
The second possibility is that the protect circuit by itselff could be defective and cause a faulty bias to trigger the cut off. This must be checked by a stage by stage Voltage check.
Since the removal of the mother board requires some experience so as not to tamper the set , you must decide on the course of action.
The other option I can suggest is to call up the Denon call centre and check up the nearrest service centre, send and receive the set to them by courier after confirming the fault and estimated costs. If this justifies then it must be thought of.
I am sure you can search for one as I am not sure the place of your residence... try a search on the web for Denon service support with your location/city.
I hope my advice helps but please open the cover to have a look inside for visible damages.
Good day
Posted on Aug 19, 2010
My harman kardon avr 120 powers off by itself in about 2-3 seconds, i press the power button again and goes off again in the same amount of time, what can i do about it?
What we are doing, in this case is looking for a shorted out speaker system, or wiring to speakers, or cables or components that are connected to the receiver that have a short circuit. This is what I would do if I were called to your house to debug your sound system.
Follow this procedure and see what happens:
Disconnect one set of speakers at the back of the receiver and turn the power button on again. See if it stays on.
If not, remove the next speaker and keep repeating the test.
If it still stays off, disconnect all of the equipment connected to the unit, one piece at at time.
Somewhere along the line, the receiver may not shut down. If that is the case
identify the the offending cable(or component)and replace or service it.
I hope this solves it for you. If not your receiver will need professional servicing,
Best Regards,
Mark
Jan 20, 2011 | Harman Kardon AVR 120 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
Denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Jan 27, 2009 | Denon AVR-2106 Receiver
My Denon AVR 2106 gives sound out periodically in all modes
So you have no sound on any Inputs?  This makes a difference, if it works on some inputs but not others.  For a factory reset - turn the unit off by the ON/OFF button (not the standby button) hold in the SPEAkER A & B buttons at the smae time, while pressing them turn the system on by the ON/OFF button, wait about 3 seconds and the unit should reset everything.
Jan 01, 2009 | Denon AVR-2106 Receiver
Denon AVR 2106 amp failure
Does it still power up for a little bit or so with no sound what so ever?....I there is no dents in it or metal pushed in causing cracked connector boards....I can take it off you hands for a couple parts I need ...because your transformer and 2 resisters are shot and it will cost almost as much as the unit cost's.
I do have a brand new never opend $649.99 Denon AVR-788 for $365.00.
And 2 used AVR units Denon and Onkyo.....ALL HDMI
call 630 742 6587
Aug 30, 2008 | Denon AVR-2106 Receiver
Input signal clicks on and off 4308ci
When you say the the input clicks on/off, does the sound cut out? I suspect that the protection circuit is kicking in. Can you please post the connections you have? # of speakers connected etc?
Thanks,
Dan
Jun 10, 2008 | Denon AVR-2106 Receiver
Denon avr 3000
Anyone want to buy a working Denon AVR-300?
hdurity@comcast.net
Dec 01, 2007 | Denon AVR-2106 Receiver
Denon AVR-2106 troubles
If the surround back is turned on,on the receiver,then the 7CH stereo will activate the 2 rear,but if it's off on the receiver the 5CH on the remote will do the same. I don't know much about the unit changing from 7CH to game,rock Arena etc.that i know will happen if u press the DSP simulation found @ the 3rd. top right button on the remote.
Jan 16, 2007 | Denon AVR-2106 Receiver
Denon AVR-2106 Receiver Logo
104 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
