Question about Kitchen Ranges
Change a 745-3055a belt on a cub cadet 2000 model # 2146
buffalonyman
  • 1865 Answers
SOURCE: Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Posted on Jun 16, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
jdhnmi
  • 143 Answers
SOURCE: I have a Cub cadet
you need a carb kit it seems like the little stopper atached to the other end of your float is not stopping gas and is flooding the carb . try pinching the hose wit a pair vise grips gently though just to stop the flow of gas and then crank over if it starts try what i wrote down about repairing the carb.if you look thre is a round bowl held on by a screw or or a spring clip remove and when you get the new kit it will have a little triangle peice with a point somtimes the tip is metal sometimes it is rubber if it is metal there is a tiny rubber peice in the bottom of that hole needs to be replaced with new one also comes in kit . in the screw there are a few tiny holes if you dont have somthing small enough to fit in the holes get a tip cleaning set from home depot or lowes it is in the welding section it costs like 2 to 3 dollars it has tiny wires with ridges on it. clean out all the holes . somtimes the screw you remove to secure the bowl on if you look in the hole you will see a brass flat head screw in the middle of the carb so you are now looking in the stem on the center of carb remove it there are more holes in that as well if you dont have the little flat head dont worry about it it is about 2 inches in length over all . install new seals and put carb together . there should be a screw to adjust the gas mixture if so you should get a new one in kit it is long with a point and should have a spring on it remove old screw tighten new screw in all the way then turn back out two and a half turns and that should be close to the correct idle speed hope this helps
Posted on May 25, 2011
alicantecoli
  • 22156 Answers
SOURCE: I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Posted on Nov 23, 2011
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Nov 23, 2011 | Cub Cadet Garden
I have a cub cadet 2000 series model 2146. When I turn the key the motor spins but doesn't start. When I take the air filter off I see gas spit out when I choke it.
You could have one or more of several problems. With the gas scenario you mention, you're getting gas INTO the carburetor. But the carb could be grungy and in need of cleaning (90 percent of mower problems in my experience). My question is this: is the thing "Firing"? like do you hear it kick in like it wants to start. If not, then it may not be getting any spark. Take the spark plug out and buy a new one for about $3 (match the numbers up on the side of the plug ceramic). It never hurts to replace it anyway. With the info you have provided here, that is all I can give you right now, but hope it helps. Good Luck.
James
May 25, 2011 | Cub Cadet Garden
I need a belt diagram for cub cadet 3235 mower deck preferably free as this is for our church.
Type in your model number to your search engine. find your model, and your diagrams will be there.
hope this helps.
Aug 13, 2010 | Cub Cadet Lawn Mower Deck Drive Belt...
How do I change the drive belt on a 1500 Series Cub Cadet Lawn Tractor
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Jun 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
