Question about Yamaha HTR-5540 Receiver
After plugging in my speakers and identifying the input and hooking it all up sound is still not coming out of the speakers. I continuously check how I set it up but its still not working.
    Novelist:
  • 169 Answers
Modern equipment has speaker select switches usually marked a and b , you could try the headphone o/p to see if they work.
First check all your connections to make sure all is ok.
Make sure you have an input selected that you have tested to ensure it is working then use that input to try the phones and then if that works try the speakers.
Always try out non working equipment at LOW level this will protect your equipment AND your hearing.
Hope this helps
Thanks for using FixYa
Posted on Aug 19, 2010
The Clip LED on Channel 1 of my SA220 is on continuously even with nothing plugged in the XLR or 1/4 inch inputs. Not getting amplification when inputs are used. Why?
That light is showing that there is power to amp in that speaker but there is something wrong with the amp or the speaker inside and nothing is coming out. You will have to troubleshoot the amp and check the resistance of the speaker to see what the problem is.
Nov 12, 2014 | Fishman SA220 Solo Performance System...
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
Can JBL Creature 2 speakers work on a Samsung smart tv
Do you happen to have the model of the TV? My Samsung only has two digital optical outputs. If your'e plugging in JBLs, you may only have an analogue input which won't work.
Mar 16, 2014 | JBL CREATURE II Computer Speakers
Speakercraft v10 subwoofer not taking input signals
Does any other speakers work through the channels you are putting the subwoofer through? Reason i ask is could there be a fault with the channel you are using i.e AUX? is your subwoofer connected with Aux cables or is it a speaker cable? If aux cable is there a slight break in the cable?
Jan 04, 2014 | Audio Players & Recorders
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
All of a sudden quit working
may i know what os ur using in ur system? try to check the sound card drivers and try to update and check if not reinstall it. before restarting unplung and plug once and check with ur system?
Dec 08, 2008 | Boston Acoustics BA735 Computer Speakers
Logitech Z-5500, no sound coming out
Hi there, Mr Dan
Happy Holidays
well, you can change, the coaxial cable for another optical? is better, if you got an optical input. or optical output to input on your SPK. that should work.try the test with a movie on.or sound continue.
Dec 18, 2007 | Audio Players & Recorders
Yamaha HTR-5540 Receiver Logo
53 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
