Question about Health & Beauty
10.92.01cartridges not engaged??? help me please
  • 17,970 Answers
10.92.yy Error Displayed When Printer is Powered
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 10.92.yy Error Displayed When Printer is Powered On This error refers to the cartridge not engaging correctly. The error may include any of the following:
10.92.00
10.92.01
10.92.02
10.92.03
NOTE: 10.92 can be caused by lack of lube in the image drive assembly. Please see service note Q1321A-05 , Q1322A-05 , Q1323A-05 , Q1324A-05 , Q1320A-05 , or Q1319A-05 depending on the printer model and check serial number range.
There are several issues that can cause this...
The cartridges not seated properly.
A broken ITB coupling lever on the front door (front door engaging tab). (Figure 1)
The copper contact on the left side of the ITB may be stuck, pressed into the ITB. (Figure 2)
The right-side cleaning blade shipping tab out of position. (Figure 3) / 1 - Toner banding / 2 - Right-side cleaning blade shipping tab
Broken Cartridge alignment knob (triangle shaped piece) on the shaft of the Print Cartridge. (Figure 4)
A damaged shutter arm on a cartridge.
A bent or missing contact on Developing Contact Assembly or Left frame assembly. (Figure 5) / 1 - Arrows - Contacts on Left Frame assembly / 2 - Circles - Contacts on Developing Contact assembly
A missing spring in the cartridge alignment knob or broken cartridge alignment knob. (Figures 6, 7, and 8)
Left rail guide is out of place, misaligned, or missing.
Left arm drum lock is broken.
Image Drum Assembly not aligning.
HVPS connector is not plugged in securely at the DC Controller or HVPS.
Transfer contact assembly is not seated correctly. (This is more likely to happen after changing this part).
When the error message is displayed and the front door is difficult to close, it could be due to a missing spring the on the cartridge alignment knob or broken cartridge alignment knob, Image Drum assembly gears not aligning, or broken ITB coupling lever on the front door. It may also prevent one or more of the cartridge shutters from opening. This can be identified by closing the door to about 1.5 to 2 inches from fully closed and watching the cartridges. If one or more do not close then a broken alignment knob should be suspect. If the front door will not close, then an ITB coupling lever could be the issue. If the coupling lever is missing or damaged, the image drive assembly will fail to engage the black print cartridge and ITB. See the photo below for location of ITB coupling lever. (Figure 1)
The right-side cleaning blade shipping tab on the ITB may be out of position as shown in Call-out 2 in the ITB photo below. (Figure 2)
The error could also be a broken Cartridge alignment knob on the Print Cartridge shaft (triangle shaped piece) or a bent or missing contact on the Developing Contact Assembly.
When the Print Cartridges are removed, check the end of each to see if the triangle piece on the end of the shaft is missing. If the cartridges are OK, check the contacts that engage with the Print Cartridge on the Developing Contact Assembly located behind the swing arm assembly toward the back of the printer and the left swing frame. See Figure 5, Developer Contact assembly, below.
Hope helps.
Posted on Aug 19, 2010
4WD not engaging not indicator light basically no 4wd
4WD Not engaging?????PLEASE HELP???? - Ford Explorer
www.explorerforum.com/forums/showthread.php?t=202197
Dec 16, 2007 - 18 posts - ‎8 authors
Well we got alot alot of snow here latly and I have a 2002 Explorer 4WD with the 4.0l and my 4WD will not engage not even 4X4 auto will...it ... 4x4 light not working/won't engage into 4wd - Ford ...
Oct 13, 2009
4x4 Troubleshooting guide - Ford Explorer and Ranger ...
Dec 16, 2007
4wd not working please help - Ford Explorer and ...
May 16, 2007
4x4 does not work - Ford Explorer and Ranger Forums ...
Jul 29, 2006
More results from www.explorerforum.com
How to find replace fix 4x4 transfer case shift module 2002 ...
? 3:07
https://www.youtube.com/watch?v=sZw3SS2Pt-4
Oct 19, 2015 | 2002 Ford Explorer
I replaced belt now blades wont engage when i pull knob please help
recheck the way you ran the belt. if you are on the wrong side if the engagement pully, the blades will not engage.
Mar 19, 2015 | Garden
The blades begin to engage when i try to start the engine and the clutch is off!! The engine wont start as a result! please help!
your engine probably sheared the flywheel key replace it but the blades engageing on there on is a big problem check blade clutch make sure its not stuck in the on position engaged
Jul 09, 2013 | Garden
Printer error 59.99
Hello thanks for using Fixya
This error mostly occurred in the secondary transfer engaging mechanism. This error may be because of following reasons
  • If Fault is in secondary transfer engagement sensor then Replace the secondary transfer engagement sensor
  • If fault is in secondary transfer engaging solenoid then Replace the secondary transfer engaging solenoid.
  • If fault is in feed motor then Replace the feed motor.
  • If fault is in DC controller PCB then Replace the DC controller PCB
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 25, 2011 | HP Color LaserJet 3500 Printer
Won't start, starter spins, won't engage
Check your Solenoid for proper operation. This Solenoid is what actuates (engages) the starter.
Hope this helps. If you find this information useful, please vote on this post. Also, if you need further help, please Comment with more information so that I may be of further assistance. Thank you.
Regards,
Oz
Jan 25, 2011 | 2005 Suzuki Boulevard C50T
Hp laserjet 3550 keeps on giving me error message of code 59.99 what do i do to solve the problem please thank you.
ur developing motor gears worn out replace them ur problem will be resolved...............
and
This error also shows the faulty secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
3. Faulty feed motor.
Action: Replace the feed motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
good luck, and do rate the solution if helps
Nov 30, 2010 | HP LaserJet 3550 Printer
89 jeep cherokee 4 wheel drive won't engage gears arn't meshing and no indicator light
If you engage the 4WD with a switch instead of manually, there is a motor in or on the transfer case. Because of the location, these can go bad. u need to check all your switches and actuators there are actuators under vehicle that clog up with dirt.also try putting vehicle in neutral before engaging 4x4.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | 1989 Jeep Cherokee
My criuse control don't not engage
  • rate me FIXYA!
  • first check fuse #4
Jun 09, 2008 | 1995 Mazda Millenia
Health & Beauty Logo
652 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
