Question about Brookstone Audio Players & Recorders
CenterPoint Energy installed a new meter at my house and my Brookstone radio (Model No. 406876) is dead. Nothing I do makes any difference, it is just blank. I understand this model is no longer available, but this is the first time I have had any problem with it. Thanks, Catherine Kerbow
    Guru:
  • 642 Answers
If you dont have specific knowledge of electronics I would advise against opening up the unit. Since the unit is completely dead it points to the power supply. The plug could be faulty(you can only check it if it is not sealed), The powercord could have a broken conductor or perhaps it is as simple as a blown fuse(This can happen when power to the unit was switched on and off repeatedly in a short space of time).
To prove any of these components you would need at least a multimeter. If you want to open the unit remove the screws from underneath(after having unplugged it off course! ). There should be one under the warrenty sticker as well. Have a look around the inside of the unit close to where the power cord is situated. On the circuit board should be a fuse. It looks like a glass tube about half inch long and as thick as a pencil with a silver cap on each end. It can be removed by lifting out first one end and then the other from the holder. This is the only part of the unit you can replace by yourself without the nescesary equipment.
I would rather suggest that you send it in for repairs or find a willing first year electronics university student to do it for you. By the end of your first year they should know all there is to know about power supplies.
Posted on Aug 19, 2010
Brookstone Model cks 2022 Alarm clock radio Instructions
I searched on your product name and found an instruction manual for a Brrostone self-setting alarm clock radio:
http://www.brookstone.com/webassets/pdf/607960p_manual.pdf
Apr 23, 2014 | Brookstone SmartSet Alarm Clock
Lost Battery Cap
Look up centerpoint on web and get contact info.
Jan 11, 2013 | Centerpoint Technologies Optics
With new batteries installed in the model 590877, I get nothing on the screen and no sound
You have to take the battery cover off and find the RESET word (same color as plastic, unfortunately, making it hard to easily see). To the left of the RESET word is a button. You have to use the end of a paper clip to push it. Then you'll notice your screen clears and you can set the date and time :-)
Jul 23, 2011 | Brookstone Tranquil Moments clock radio
Will not illuminate
The battery is most likely dead, check your owner's manual for battery replacement instructions.
Dec 25, 2009 | Centerpoint Technologies CenterPoint AR22...
Cobra 29 classic "swing kit" ?
A swing kit is nothing more then a Cap and a resistor. There really isn't a different way to do a swing kit, unless you do variable power, which you don't need unless you are going to run a linear, and even then you can just set the dead key with a swing kit.
you need a watt meter, preferably one that reads peak and average watts. If not, average will be find.
Open the bottom cover of the radio. Hook the radio up to the watt meter, use a dummy load or have it hooked to the antenna. Never key the radio with an antenna or a dummy load.
Find VR4. Its toward the back right of the radio. Turn it all the way to the left. That increases your modulation.
Next find L14. it is at the back in front of the final resistor. While making a steady sound into the radio, just make an ahhhhhhh noise. Back the slug out of the tank until the needle hits peak. Don't move it out any more or you will over bias the final.
Now you will need a 220 uf electrolytic cap, and a 100 ohm 1/2 watt resistor, both of which you can get from radio shack. (this is your swing kit.
To the right of the tank slug is a jumper maked JP36. Us soldering wick to remove the solder and pull out the jumper. Now put the cap in it with the stripe facing the back of the radio.(that is very important. the other way you will blow the radio.) Solder it in place and cut the extra leads off. Now on the back of the board were you soldered in the cap, solder the 100 ohm resistor in between the 2 points.
The amount of resistance determines you dead key. you will be at about a 2 watt dead key which is good for swing and if you want to run a linear. The higher the resistor the lower the dead key, and the lower the cap, the higher the dead key.
That is your basic peak and tune with a swing kit.
Dec 23, 2009 | Cobra 29 LTD CB Radio
I need to replace the battery on my centerpoint scope
I'm not sure which model you have but the most common battery location is under the reticle switch on the ocular lens housing, you have to hold the base of the switch with one hand and turn off the cover with a coin in the other hand. The most common battery for these scopes is a CR2032 button style battery.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks!
Dec 05, 2009 | Centerpoint Technologies CenterPoint AR22...
I plugged in my Brookstone Smartset alarm clock and the wrong time came up. I tried to click on the time zone button to change and nothing happened. What to do?
Brookstone Clock Radio Model CKS5369
Time is set using the RH button on the Month/Date, Time, and Year buttons. If you are only setting time, press the Time button and hold it down while pressing the Tuning/Set buttons for a lower or higher time. If you hold the Tuning/Set button it will shift to a fast change or press and release for one number change. Be sure to note the AM or PM light to the left of the time display.
Aug 17, 2009 | Brookstone SmartSet Alarm Clock
I would like an instruction manual for a Brookstone Tranquil Moments Bedside Clock Radio model #406876
Can I get an instruction manual without paying $12? That is all I want, but that is too much to pay.
Jul 22, 2009 | Brookstone iHome Alarm Clock Radio Remote...
No transmission
Check the conductors where the battery passes energy to the radio, ake sure the tabs are clean and bent out to make good contact. The electrical draw in the battery is much lower than just turning on the unit opposed to pushing the PTT button. Also, use a volt meter and make sure the batteries are not weak and dropping voltage when you use the PTT button. These batteries do need replaed from time to time, especially if you never allow them to run all the way down to dead. This should be done (running batteries until they're dead) once every 1-2 months on any re-chargeable battery, it will greatly extend the battery life. This is true of all re-chargeable batteries.
Jul 09, 2008 | Motorola Talkabout T5420 (14 Channels)...
98 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
