Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
How do I clean the coils. I removed the kickplate but can't get vaccum or brush under-space too small
  • LG Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 19, 2010
Whirlpool refrigerator clean coils
For most machines, there is a kickplate located at the lower portion at the front which can be pulled off to expose the coils. You can either use a coil brush or a vacuum with an attachment to clean them
May 31, 2012 | Whirlpool Refrigerators
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
Clean coil light comes on - requre detail
Remove the front grille, vaccum the coil or brush with coil brush.
Jul 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
NOT COOLING PROPERLY IN THE DOWN CHAMBER OF DOUBLE DOOR
remove bottom vent cover at front of fridge. just clips in place. look under neath and you should see a coil. its probaly caked with dust. use a shop vac or vaccum cleaner with small enough hose to insert under the fridge directly to the coil. remove all dust. dont use anythng sharp or pointed to clean coil, as coil can be punctured.
Jan 09, 2010 | Refrigerators
My amana model #SXDE27NE says i need to clean the coi. How do i do this?
remove the lower kickplate, and youll find the "coils" under there, with a refrigeration coil brush youll be able to vaccuum all the dust out from there
Feb 21, 2009 | Amana Refrigerators
Amana side by side coil cleaning
removethe lower kickplate , under the doors, then with a refrigeration coil brush(avaailable at te hhradware stores) and a vaccumm you can clean the coils
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
209 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
