Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
My work-issued Gateway laptop previously connected just fine to my wireless. I turned it in to our tech dept. in June to be re-imaged and updated. When it was returned to me last week, it could no longer connect to my home wireless. When I try, it sees the connection which is still set as a preferred, automatic connection, but after it tries for a short time, it says that it failed to connect.
  • 724 Answers
Did it ask for a Wep KEY?
Posted on Aug 19, 2010
I have a windows 8 gateway laptop(NE71B Series) and its seems as if my wifi switch is disable. Anyone with a bit of advice on how to resolve this problem would be very helpful.
Recently had a coworker bring me a Gateway NE71B laptop.
Complaint: No wireless even using a VZW 4GLTE hotspot.
Observations:
; All drivers and devices are functional with no errors or conflicts.
; Wireless adapter has power and is not in Airplane mode.
; No wireless networks are visible even though there are normally as many as 12 networks available within the area.
; Wired Ethernet adapter works without issues.
Solution:
Turns out the BIOS was v2.05. After updating the BIOS to v2.13, wireless connectivity is functional. All locally available wireless networks (SSIDs) are visible.
Notes of caution:
; A failed BIOS update will invalidate your warranty per Gateway chat support rep.
; Ensure you have a fully charged battery before updating the BIOS.
; Ensure your AC adapter is plugged in and functional prior to starting the BIOS updater.
Jan 22, 2013 | Computers & Internet
NV55C Gateway Lap Top cannot connect to wireless router
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
Jan 23, 2012 | Gateway NV55C03u Laptop
Gateway model m320 wireless will not work
installl drivers
and update from gateway site
Jun 03, 2010 | Medion MD 96340 Laptop
Laptop says validating identity
Right click on wireless network connection and go to properties. From the Wireless Networks tab, choose your wireless network and then click Properties.
Click the Authentication tab. On the Authentication tab, Uncheck"Enable IEEE 802.1x authentication" for this network check box. and click oK.
Now reconnect to the wireless network and you will be able to connect to it.
IF you still face issue then please enable WPA encryption on the wireless router and that should work fine with both the laptops.
Rate it, if it helps.
Jun 27, 2009 | Belkin Computers & Internet
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Laptop connected to WiFi yesterday but now cannot
try rolling back to the previous driver and also uninstalling and reinstalling the last driver update try this last in safe mode (try one thing at a time and test)
check if there's a firmware update for your wireless lynksys router.
although you got an odd problem... because you're mom laptop is fine so it's gotta be on your computer... mmmm.. still worth a try i think.
good luck!! post your findings for follow up!!
Dec 05, 2008 | Computers & Internet
Wireless connect
Call your ISP and demand a DSL tech visit. It sounds like either you do not have the correct password in your gateway to allow for access OR you have your computers wireless connection trned off. On my dell, i use Intel pro wireless set to connect. Your ISP's csr support should be able to get this up and running for you.
Mar 14, 2008 | Westell Wirespeed VersaLink...
Gateway pc, windows vistsa, cant connect to router
Try using 'Network Magic' free download from their site. I find that this product makes connecting easy. You do not need to purchase the PRO version, the free will work fine for connecting.
If that does not work, log into your router using a wired pc and check if MAC addressing is enabled, if it is you will need to update the table with your new laptop's MAC.
If not, disable security and test to see if you can connect, if you still can not then you may have a issue with the pc. If you can, then check to ensure that the encryption you are using is supported by the PC's wireless card.
Turn reset the password on the router, re-enable security and try again.
Nov 30, 2007 | Gateway Wireless-B PC (wbm-120)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
