Question about Panasonic KX-T7731 Corded Phone
How do I reset time and date - Panasonic KX-T7731 Corded Phone
Which system do you have? Below are the Panasonic systems. Be sure you find yours.......
Panasonic XDP 824/1232
All programming is done at ext. 101
1) Press the program button, followed by *#1234
2) Dial 000, then follow the prompts on the LCD
KX-T308, KX-T616
  1. Use phone with intercom number 11. It will change the time for all phones.
  2. Keep handset down and press INTERCOM button.
  3. Dial 77.
  4. Dial the hour, with two digits (e.g. 03 for 3 o'clock).
  5. Dial the minutes, with two digits (e.g. 07 if it is now 7 minutes after the hour).
  6. Dial 0 for AM or 1 for PM.
  7. Press #.
  8. Press SP-PHONE
Panasonic KXT Series Telephone System
Setting the time must be completed from an LCD Display phone at Extension 11, using the telephone keypad. This system type requires "Easa-phone" series or a 7000 series model telephone (the model number is listed on the bottom of the phone) that has one or more small switches located at the rear of the phone. Digital "XDP" phones can not be used on this system type!
To set the time:
  • Lift the handset or press "SP-Phone" button on Extension 11.
  • Dial "77"
  • Enter the hour with 2 digits. (01 through 12)
  • Enter the minute with 2 digits. (00 through 59)
  • Dial (0) for AM or (1) for PM.
  • Press the "#"
  • Wait for confirmation tone. (Instantly after pressing the # button, new time counting will start).
KX-TA624
  1. Use phone with intercom number 101. It will change the time for all phones.
  2. Move MEMORY switch on rear from SET to PROGRAM.
  3. Dial *#1234
  4. Dial 000
  5. Press NEXT ("Sp-phone")
  6. Press Right Arrow ("FWD/DND") four times until you see the time displayed
  7. Change the hour with the keypad
  8. Press Right Arrow ("FWD/DND") to reach the minutes field
  9. Change minutes with the keypad, if necessary
  10. Press AUTO DIAL/STORE
  11. Press HOLD
  12. Move MEMORY switch on rear from PROGRAM to SET.
KX-TAW848
  2. Press PROGRAM (or PAUSE, if you don't have a PROGRAM button.)
  3. Dial programming access code (probably *#1234)
  4. Press NEXT (SP-PHONE, if you are not using the programming template).
  5. You'll see "Date & Time Set" on your phone's display
  6. Press STORE
  7. Press NEXT to see hours and minutes.
  8. Use your keypad to change the hour
  9. Press STORE.
  10. Press HOLD.
  11. Press PROGRAM
KX-T123211D
  1. Use phone with intercom number 101 (probably the receptionist's phone). It will change the time for all phones.
  2. Move MEMORY switch on back of that phone to PROGRAM.
  3. Keep handset down and press 0 on touch-tone dial.
  4. Dial year with two digits (e.g. 97 for 1997).
  5. Dial month with two digits (e.g. 01 for January).
  6. Dial date with two digits (e.g. 03 if today is the third day of the month).
  7. Dial day with one digit (1 for Monday, 2 for Tuesday, 3 for Wednesday, 4 for Thursday, 5 for Friday, 6 for Saturday, 0 for Sunday).
  8. Dial hour with two digits (i.e. 01 for 1 o'clock).
  9. Dial minutes with two digits (i.e. 07 for 7 minutes).
  10. Dial 0 for AM, or 1 for PM
  11. Press either AUTO DIAL/STORE or AUTO/MEMORY, depending on your phone.
  12. Move MEMORY switch on back of phone to SET.
Panasonic DBS 824, 40, 72 & 96
- From the Attendant's display phone.
  1. Press "On/Off"
  2. Press "Prog"
  3. Press " ##"
  4. Press "FF1 key"
  5. Dial 1#, 2#
  6. Dial the time in 24 hr format.
  7. Press #
  8. Press "On/Off"
- From any display phone in the system.
  1. Press "On/Off"
  2. #98 + Password
  3. Press "Prog"
  4. Press " ##"
  5. Press "FF1 key"
  6. Dial 1#, 2#
  7. Dial the time in 24 hr format.
  8. Press #
  9. Press "On/Off"
Panasonic DBS 576 & 576 HD
From any display phone in the system;
  1. Press On/Off
  2. Press "Prog"
  3. Press " * * "
  4. Dial the " Password"
  5. Press "FF8"
  6. Dial 81001
  7. Dial in new time in 24 hr format.
  8. Press Hold and then "On/Off"
Posted on Aug 19, 2010
Time/date won't retain
The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
Aug 20, 2014 | Canon PowerShot Cameras
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
How do i reset date after battery change? or where can i cet a pdf file a9no calliber number on case or movement but its a timex perpetual with indigo light approx 30 yers old
to reset the date manually, pull the stem out to the second position to reset TIME; manually continue setting time until the date is on the correct day/date.
I had to do this to get back to the proper date when my timex was off by a week. Nothing else worked. 14 times around (twice per 24 hour day) and each time I passed "midnight" the date advanced.
blessings!
Mar 12, 2011 | Timex Watches
Reset Date and time
yes its possible. Please remove the internal battery once and then put it inside after few minutes. This will reset the date time. while you switch it on once again. it will prompt you to enter new date and time.
Regards
Sweet Rascal
Jan 28, 2010 | Fuji FinePix J10 Digital Camera
How to reset time and Date?
It must get the date and time from Caller ID when it gets a call. When I first set mine up, the date was 01/01 and time 12:00. Now after receiving three calls, the date and time are correct.
Jun 11, 2009 | Southwestern Bell Lands Phones
Can't find my manual and need to reset the date and time
if system DK series must set at port "00"
#402 to check the port number with displayed phone
#651 DDMMYY - for date
#652 HHMMSS - for time
#653 to change the day
Apr 08, 2009 | Toshiba DKT3010SD Corded Phone
Unable to change today's date on new Samsung SHG-D980
To change the date select:
menu, settings, time and date.
Drag down the screen until you reach the Date box.
press once, press a second time.
enter the date and press OK
save and exit
hope this works, it worked for me and I had exactly the same problem.
Feb 24, 2009 | Samsung SGH-D980 Cell Phone
Date & time reset
try and enable automatic update of time and date in the settings..
Nov 02, 2008 | Nokia 6300 Cellular Phone
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
When the batteries die I have to reset the date and time again in order to take pics! Was there something that I missed or did wrong?!
The manual states that when you change the batteries, you will have to reset the date and time; this is normal operation for this camera (though it is a pain!!!)
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Panasonic KX-T7731 Corded Phone Logo
334 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
