Question about Cycling
When the handlebars are turned, the wheel does not turn with them. Kettrike Air Navigator tricycle
    Problem Solver:
  • 14 Answers
  • It sounds like the quill insert is loose. The handle bar connects to the stem, the stem connects to the quill, the quill connects to the steerer tube.
  • while sitting on the bike, tighten the quill adjustment bolt a half turn at a time until the handlebars turn instantly with the front wheel.
Posted on Aug 19, 2010
HAD A FALL WITH MY MOTORCYCLE, HANDLEBARS AND FRONT WHEEL ARENT IN ALIGNMENT.HOW DO I GO ABOUT GETTING IT TRUE AGAIN?
Hi, Anonymous if you have a minor accident, lay your bike down and the front end gets 'TWEAKED" where the front wheel is going in one direction and your handlebars are going in the opposite direction, despair not, there is a quick fix.
1. If your handlebars are turning right turn the front end all the way to the right making contact with the fork stop. Find the 10:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the left fork stop and find the 2:00 o'clock position and give it a soft kick.
2. If your handlebars are turning left turn the front end all the way to the left fork stop. Find the 2:00 o'clock position on the front wheel and give it a good swift kick with your foot, put the front wheel in a straight-forward position and eyeball the orientation of the handlebar. Usually, it only takes one or two kicks to get everything back to normal. If you overshoot, no big scare, just turn the front end all the way to the right fork stop and find the 10:00 o'clock position and give it a soft kick.
Continue the process until you are comfortable with the alignment. It's always a good idea to retorque any accessible handlebar riser bolts as well as the upper and lower fork clamps to proper book specs.
Good luck and have a wonderful day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 25, 2017 | Motorcycles
How do you raise handle bars?
There is a long bolt at the top of the neck which is used to pull a tapered nut into the bottom of neck.
Loosen this bolt by 3-4 turns and tap it down to release the taper. Secure the wheel from turning while turning the handlebars and the handlebars can then be raised or lowered as required. Straighten the handlebars in relation to the wheel and retighten the neck bolt and you are done.
Aug 16, 2015 | Cycling
Front pedals
Yes, you got the bolts too tight on the axle shaft. You have to "sets" of nuts, the inner and the outer. The inner nuts on the shaft, which go inside the fork, should be adjusted so the wheel is rolling freely, with just a tiny "slop". Now, you will need to figure out a way to tighten the outer nuts to hold the wheel on the fork without turning or moving the inner nuts! Some bicycle shops use specially thin wrenches.
Be blessed.
Aug 08, 2013 | Schwinn 12" Roadster Tricycle
Why are the rear wheels locked up on my toddlers schwinn tricycle?
I took the fenders off to give a little more space for the wheels to move. Don't tighten the nut and washer right up against the black plastic spacer on the rim. Schwinn should be sending out locking spacers or nuts to fix the problem, but I don't see that happening.
Sep 23, 2012 | Pacific Cycle s Schwinn Roadster 12"...
2004 Lincoln Navigator when making slow turn wheel fully turned in either direction the truck comes to a complete stop while in gear. I have to press the gas hard to move. I had a strutmasters kit...
check and adjust the turn stops so that a turn angle of 20 degrees is the maximum
It is possible that with the changed suspension that the steering on full turn is making the wheels at such an angle that the vehicle is trying to push the wheel sideways instead of rolling it around the corner
Aug 02, 2017 | 2004 Lincoln Navigator 4x4
The tricycle back wheels won't turn easily. It is almost as if a brake of some sort is being used when my son tries to peddle. There isn't anything rubbing against it on the outside (the fenders...
You have a better chance of diagnosing the problem than we do. Eyeball and listen to it. Something is rubbing somewhere or bearings have frozen. Do both wheels drag?
Aug 07, 2011 | Schwinn 12" Roadster Tricycle
Tricycle loose handle bars.
You need to install a shim so the bolt has more to clamp on. To do this, loosen the bolt you have been tightening enough that you can pull the handlebars out, then about 3 or 4 more turns. Get an empty soda can and with a pair of scissors, stab into the side of the can near the bottom and cut off the bottom end. Then cut about 2 inches up and cut around the can so you have a roughly 2 by 5 inch strip of aluminum. This is your shim (you may have to trim some length if it doesn't fit). Wrap it around the bottom part of the handlebars where it will go back into the part where the bolt is. Make sure you wrap it tight or it will be hard to put in. Slide the handle bar with the shim on it back into the other tube and tighten the bolt. The end.
Jul 13, 2009 | Huffy Cycling
Kettler Air Navigator Tricycle
My husband and I just put this trike together and had a similar problem - the front wheel always turned the pedals and we couldn't figure out how to stop this. The manual for the trike is awful and very hard to understand. After spending a LOT of time analyzing the pictures and doing all sorts of weird things to the pedals, I found a posting on a website that said they'd had the same problem, but had removed and re-attached the front wheel and the problem was suddenly fixed. Sounds too good to be true, right? Well, we noticed that in one of the manual's pictures that the air valve for the front tire was facing the other direction - we'd actually put the tire on backwards. I took the tire off, put it back on facing the other way, and suddenly it all works as it's supposed to.
The thing is, you actually don't have to "do" anything to change from free to fixed and keep the pedals stable. If my daughter pushes the pedals around, they move around, and if she keeps her feet steady on them, the wheel continues to go around while the pedals stay put. It truly is automatic, which the diagram in the manual does a terrible job of conveying.
Hope this helps someone. We like this trike, but the directions are beastly!
Aug 18, 2008 | Kettler Kiddi-o Supreme Stroller Trike
Cycling Logo
128 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
