Question about Sharp Audio Players & Recorders
I was just wondering what the output in watts are for the sharp stereo C422. I am looking for one comparable to this.
    Problem Solver:
  • 17 Answers
IT IS 20 WATT PMPO (PEAK MUSIC POWER ).. 20 WATTS PER OUTPUT APPROX..REGARDS yammandan
Posted on Aug 19, 2010
Testimonial: "Thanks for the info."
Why is the volume on my JVC KD-SR80BT limited to 30?
The number on the panel of your car stereo is not a measure of actual volume. It is just a comparative scale, with 0 being the minimum and 30 being the maximum. The volume as measured in decibels is dependent on the power level of the amplifier and impedance of the speakers. The internal amplifier puts out 22 watts per channel (50 watts peak) into 4 channels, and there are output jacks for an external amplifier(s). Product specs in link.
JVC KD R850BT
Mar 01, 2015 | JVC Car Audio & Video
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
I replaced my mini component stereo (360 watt) speakers with new speakers that apparently can handle up to 600 watts. If the volume is too high on the receiver, the power cuts out. I think this is because...
probably you are right due to high impedance of the speaker the receiver cant handle it, the mini component can handle 80 to 100 watts only. you need a high watts amplifier to used your 360 watts speaker, just connect it to the audio output of the mini component. thanks
Aug 30, 2009 | Sharp CD-E99 CD Shelf System
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
We have moved to new zealand will the NAD c422 work here?
You can usually get a power converter locally so you can use products from a different country. I have no idea what radio stations you can get....:)
Mar 21, 2009 | NAD C422 2 Channels Tuner
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
221 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
