Question about Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not heating
Dryer tumbles, etc. but no heat. Cleaned lint trap and the lint "pit", checked vent, all clear.
  • nobother Jul 14, 2008
    I have the same problem and am in the middle of diagnosing & repairing. There is a temperature sensor / thermal overload protector (circuit breaker) in the machine that protects from overheating. Remove the four plastic plugs, then the four screws at the top /front. Remove two scres at the rear and the top comes off. Remove 20+ off the back. Take the back off and at the bottom of the machine is a little black electrical component with a red reset button. Reset the button and you should be back in business. BUT... why is it overheating in the first place. Check your entire exhaust system. It is verly likely that the flex hose and ducting (PVC is a poor choice - several reasons) is clogged - at least partially. Thouroughly clean or replace it. Reset and reassemble. Unfortunately, there is apparently more to my problem. My next step is to replace the temperature limiter and see if that does it. It heats when I re-set it, but soon stops heating again - requiring another reset. I hope this helps someone!
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Dryer runs but no heat this is a gas dryer
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Whirlpool LGR3624JQ Gas Dryer
My dryer runs but no heat.maytag neptune gas dryer.
Good Luck!!
Sep 22, 2010 | Maytag Dryers
Roper gas dryer will not heat. Igniter?
Good Luck!!
Sep 10, 2010 | Roper RGX4634KQ Gas Dryer
Dryer is not heating up to dry the clothes
Good Luck!!
Sep 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer quit heating
Good Luck!!
Nov 01, 2009 | Whirlpool GGQ8831L Gas Dryer
1 year old Kenmore dryer tumbles but doesn't heat.
If it is 1 year old, call Kenmore , they will probably fix it as a courtesy call.
If not quote that the machine is not fit for purpose as it should not have gone wrong so quick
Sep 24, 2009 | Kenmore Dryers
My amana gas dryer is not heating
Good Luck!!
Sep 04, 2009 | Amana NDG5800 Gas Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
432 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
