Question about Homelite 'Yard Broom' Leaf Blower
Hard to crank and to keep running - Homelite 'Yard Broom' Leaf Blower
    President:
  • Homelite Master
  • 1,545 Answers
These machines are not maintenance free like some car batteries claim to be. The require care and tuneups just like your car or mower does. This most likely is a fuel delivery issue and if the unit has any age on it, the time has most likely come to rebuild the carb or at least replace the diaghrams with a kit. The machine may have other issues too, so start at the fuel filter in the tank, observe the condition of the fuel lines and check inside the carb for gum,dirt, and/or varnish. Clean the miniature screen inside the carb and spray the carb internals with a non-flammable brake cleaner aerosol spray.
Posted on Aug 19, 2010
1990 buick riviera cranks but wont start
Check your fuel pressure; if it is within specs, have a muffler shop test your back-pressure from your catalytic converter. There are other things that can cause strange problems like this but it is a process of elimination.
Mar 12, 2014 | 1990 Buick Riviera
My BMW 320d stopped running while I was driving and now it cranks but does not start
water in the fuel pump open the drain plug on the bottom of the pump.to drain it .then close it .now pump up the pump as hard as it will go .get someone to turn over the engine as you keep pumping .
Dec 21, 2013 | 2000 BMW 3 Series
Replace rods in 2001 prism
Not good omen. Likely a bearing seized or broke on your crank shaft. knocking is usually an indication of crank shaft problems - it is possible that you have top end damage as well. Prognosis is poor - rebuild / replacement is likely required. Don't plan any long trips - if you drain the oil you may find metal shavings etc... Depending on how bad the damage is you may be able to keep driving it but it does sound bad if you find it hard to keep running - if you do want to limp around for a bit drain the oil and change the filter and keep the oil up to it.
Jan 17, 2013 | Cars & Trucks
Cranks fine engine runs fine but you turn off. it is hard to crank keeps turning over finally cranks
CLEAN FUEL INJECTORS.THEY ARE FLOODING THE ENGINE.WHEN YOU TURN OFF ENGINE DIRTY CLOGGED FUEL INJECTORS WILL KEEP LEAKING FUEL FLOODING ENGINE.ALSO REPLACE AIR FILTER.
Oct 25, 2010 | 1995 GMC Yukon
1992 Buick Park Avenue - car runs great..when it runs.
The crank sensor is located on the side of crankshaft damper/pulley it mounted on a bracket. However it think that you may have a map-sensor problem that's very common with this vehicle. The crank sensor is not hard to change at all. Good Luck get back in contact if you need more help
Dec 18, 2008 | 1992 Buick Park Avenue
46cc cranks but wont keep running if trigger is released
The small ports and passages within the carburator is blocked,the carb must be disassembled and cleaned and possibly replaced ..
Nov 24, 2008 | Poulan Pro Chain Saw 46cc 20"
Homelite 'Yard Broom' Leaf Blower Logo
60 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
