Question about RCA DRC8295 DVD Recorder/VCR Combo
I can not record. I get a the following: Impending timer cannot record to this disc Please insert a recordable disc I have been using the same DVD RW 4.7gb discs forever.
  • tje2 Aug 20, 2010
    I have tried 3 brand new DVD+RW discs. These are what I have used for years and are recommended in the Users Guide. I have also tried 2 different Phillips laser lens cleaners. Right now nothing helps. What might be plan B other than make this unit a doorstop.
    Thanks...Tom
  • tje2 Aug 21, 2010
    Is it possible that there might be another solution. I tried the compressed air and q-tip route. No joy!
  • 4,889 Answers
I have seen this happen too many times. Your DVD recorder's lens/laser is dead. You should get the lens/laser assembly repllaced to resolve this problem.
Posted on Aug 21, 2010
  • RCA Master
  • 11,800 Answers
This happens because the rewritable disk is either worn out - try a new one - or that the disk must be formatted before use- you already have something on it that is corrupted .
BTW it's highly advised to use DVD-R disks in this unit.
But it may also be a very dirty laser lens - have you tried cleaning it?
Posted on Aug 20, 2010
  • Azrael SRL Aug 20, 2010
    Last hope attempt - open the case and access the laser lens, use a can of compressed air and blow away every single speck of dust you see and especially under the lens, then use a fine q-tip to clean thoroughly the lens. If even after that it doesn't work then the dust has been burned on the lens - either find a replacement laser head or junk it.
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: http://www.funaiamerica.com/product/product.php?id=877 . Click on the Downloads tab. The direct link is currently http://www.funaiport.com/download/download.php?id=3361&brand=FUNAI . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
How do i rewrite over a disc that is full
If you are using a DVD-RW or DVD+RW, you can format the disc by performing "Format". You can format DVD-RW for either video mode recording or VR mode recording. DVD+RW can be format in order to erase all content of the disc.
You may not be able to reformat a disc that is not previously formatted by your recorder an example would be a. DVD disc formatted by PC or another recorder.
Follow these steps to re-write:
Insert a recordable disc.
1 Press [SETUP].
2 Select "DVD Menu",
then press [ENTER].
3 Then select "Format", and
press [ENTER].
4 select "Start", then
press [ENTER].
5 Confirm by selecting "Yes", then press
[ENTER].
Formatting will start.
6 Formatting is completed.
When the disc is ready for you to rewrite to "100%" is indicated.
Formatting 100%
Mar 29, 2010 | Toshiba DR420 DVD Recorder
Sony DVD Recorder RDR-HXD990 will not timer record.
DVD wont consitently read discs drops out even though no scratches on discs
Jan 29, 2010 | Sony RDR-HX510S DVD Recorder/HDD Recorder
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Eject dvd doesn'start recording
This sometimes happens when a disk is not formatted prior to recording .. the DVD is telling you it cant record on it at the time you want because it would have to format first and then start recording so missing the times you have set .
Best thing to do is use re- recordable discs only and format prior to use then the dvd should start straight away .
If not then the set has a serious read problem and requires looking at by a qualified engineer ... Regards Vortash
Jan 30, 2009 | LG RH266 Recorder
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
Timer Recording
This is from the KR10 manual. Hope it helps.
1. Set the clock before setting a timer.
2. Insert a recordable disc with enough space.
Then:
1. Press [TIMER PROG] on the remote
2. Use up/down arrows to select "New Program" then press [ENTER]
3.Use up/down arrows to enter the date, then press right arrow
4. Use the arrow keys to enter the start and end time, then press right arrow key.
5. Use the up/down arrows to select the external input position to which your cable/satellite box is connected, then press [right arrow]
6. Use the up/down arrows to select a recording mode.
7. Press [ENTER] when all items are entered.
8. Press red [I/O ON STANDBY] to set a timer programming.
DO NOT FORGET THIS LAST STEP! The timers will not work if the recorder is not in standby mode.
Jul 24, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
RCA DRC8295 DVD Recorder/VCR Combo Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
