Question about HP laserjet Cp2025dn color Card Printer
I must always hit the OK button for the printer to print.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
Try doing an NvRam (Hard reset)
1 Turn off the printer.
2. Simultaneously press the Right arrow button and the X button. Keep these buttons depressed
as you turn the product on."
3. When Permanent storage init. appears on the display, release both buttons.
4.When the product has finished the NVRAM initialization, it returns to the Ready state.
Then set the paper settings on the driver, Go to printer and faxes, right click on the CP2020 series icon, got properties and finall printing preferences, se the type and size of paper you are using.
Posted on Aug 24, 2010
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
Ricoh Aficio CL3500N Laser Printer How do I clear the print que from the printer?
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jul 01, 2010 | Ricoh Aficio CL3500N Laser Printer
How do I cancel an order to make it stop printing and clear it out of the system
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 23, 2010 | Zebra 105SL Thermal Label Printer
Won't print , status que sys it is.
Click on Run
Alternate method,
Click STart
Click RUN
Type
Jun 22, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Lexmark x4650 when printing grey turns out black, help please.
Hi. It might be just the print settings in the printer. You might be printing in Best Mode - it uses a lot of ink. Try to print your file again. But before you hit Print/ok button on your computer, go to Preferences first and check the print settings. Make sure to choose Automatic or Draft Mode, then hit Ok to save the setting. Print the file. Hope this resolves the problem. Good luck!
Mar 16, 2010 | Lexmark X4650 InkJet Printer
Trying to print microsoft excel spreadsheet printer keeps saying load tray A4 both trays have paper whats going on
This isn't actually a problem with the printer, but with Excel's print preferences.
In Excel, select File->Print to bring up the print dialog.
Select your Dell 3100 if it's not the default, and then hit the Properties button just to the right of the printer name.
On the printer properties dialog, there's a field named "Paper size"
Click on that field and select "Letter (8.5 x 11 in)" You may have to scroll to find this selection.
Hit OK to close the printer properties dialog, then hit OK to print your worksheet.
If this helps, be sure to hit the "thumbs-up" for me!
Dec 24, 2009 | Dell 3100cn Laser Printer
I want to print a configiration page from my hp office jet 5610 all in one printer
If you want a snapshot of how the printer is configured and a quick self test, to the following from the front panel of the 5610.
1. hit the "Setup" button.
2. hit the right arrow to "Print Reports"
3. hit the "ok" button
4. hit the right arrow to "Self Test"
5. hit the "ok" button
The printer will then print a report that tells you the series and model number as well as the serial number, Service ID, LIU type, Country/Region, The active I/O connection, all of your cartridge alignment settings then display color bands for all your cartridges. It also tells how many pages your printer has printed (I am up to 2,068 on the cartridges that I reload myself) as well as the firmware version.
Good luck and hope this helps. -Dan
Oct 10, 2009 | HP Officejet 5610 All-In-One InkJet...
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Jun 18, 2007 | Epson LQ-570e Matrix Printer
HP laserjet Cp2025dn color Card Printer Logo
358 people viewed this question
Seeker5211
Seeker5211
