Printer paper feed problem. I have a KYOCERA KM-1820 4 in one printer. It has a paper feed problem. The paper starts to feed from the lower drawer and then stops. A paper jam light comes on. If I open the drawer I see the paper is folded over in kind of a U shape. If I just close the drawer again it feeds on through. So each time I have to open the draw and slam it shut to print each page. Real PIA
  • Gerald Gier Aug 19, 2010
    After I took the cartridge out I was not sure were the print head was.
    I have had this problem for 2 years. You are the first person to come up with a solution. As you know this is a commercial machine and the owners manual leaves a lot to be desired since Kyocera expects you to keep going back to the dealer for help. If you have any other tips or can direct be to useful sources of maintenance help I would appreciate that too. Thanks so much
    Jerry G
    g502@charter.net
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check that there is no paper jam. Open all the doors, take out the paper tray, take out the cartridges and visually inspect if there is any tiny piece of paper or foreign object is stuck anywhere in the printer. Turn it off and unplug it from all cables (power, USB, etc). If still the issue is not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 19, 2010
  • Rylee Smith
    Rylee Smith Aug 19, 2010
    Print head is right beneath the Ink cartridges, I mean the area where the cartridges sit is print head.
The paper repeatedly jams, it's half folded in the tray. you can pull the drawer out and back in and sometimes it clears the jam. we've chg'd out the ink cartridge and it continues to happen.
First (the priceless solution) clean the feed roller and the separator kit using a piece of cloth (not paper) and glass cleaner or alcohol.
Otherwise replace the 2 solenoids (feed and regist) and probably the separator kit
Oct 09, 2014 | Kyocera Copystar CS-1820 Black and White...
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
How do you make a kyocera KM-1820 make 2 sided copies?
Hello, The Kyocera KM-1820 does not support automatic duplexing (double-sided).If a double sided copy/print is required you would have to do it manually, print the first side, then flip the paper over and run it back through the printer again for the second side.
Pre
Jan 14, 2011 | Office Equipment & Supplies
My kyocera printer km 1820 won't use paper on the loaded auto tray. It you press paper select - then auto - it asks for paper to be loaded on the MP tray. The local technician told me to press...
cheap kyocera mita copier repair and parts installation just txt or call 09194851549, 09168932315 also offering free estimate within metro manila (ncr) philippines any kyocera mita brand we can fix it!!!
Dec 03, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
I have a kyocera km 1820 copier at work and cannot figure out how to navigate it to make 2-sided copies???
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
May 20, 2010 | Kyocera Copystar CS-1820 Black and White...
I have a KM-1820 and the problem is CF223 error.
Meaning Motor error in the option bulk paper stacker HS-8E. Suggested causes Defective harness (S02400) between engine board and option unit interface connector. ? Defective option bulk paper stacker HS Corrective action Replace engine board Replace harness
Oct 21, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Computers & Internet Logo
489 people viewed this question
David Payne
David Payne
