Question about Garden
Can you tell me if the power bright p2300-12 inverter is a good buy and any touble they might of had?
  • 10,865 Answers
Hello. This is a quality product. I recommend it.
Posted on Aug 19, 2010
I have sound no picture on 42LA45H replaced slave and master boards sill no pic
Hi Stacy,
I appreciate your DIY effort. But there are certain conditions for a good Inverter board to work. A good Inverter board will not work if it does not get power from power supply board and certain other commands like "Inverter on" and "brightness control" from the main board. All these things are printed near the connector on the inverter board.
May 28, 2015 | LG 42LC2D 42 in. LCD HDTV
MY PHONE SAMSUNG MONTE GT5620 IS SHOWING DISPLAY DIM I ALREADY CHECK THE BRIGHTNESS SETTING BUT IT IS OK...TELL WHT I DO
It sounds like the inverter for the back light is going out. the backlight is inside the lcd display. you can either buy a new lcd and replace, or have a shop do it. or if you have insurance on phone i suggest that first. Good Luck
Nov 29, 2013 | Cell Phones
Greenlight but no ac out
voltage regulator is bad. Most likey bad caps.
May 16, 2013 | PowerBright Power Bright 2300 Watt Power...
No ac output
a few checks 4 ya.. check and test fuse or replace must have a hot battery ! nothing ? dig inside of it(only if not in warranty) use volt meter to see if it is getting 12 volts inside of the unit.. thats about all you can do.. buy a new one return this bad one...
hey if i was of help please tell me/// thanks jay
Sep 12, 2010 | PowerBright Power Bright PW2300-12 12 Volt...
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
What size Battery should i use to power my Power Bright 3500W inverter
If you want to use it on full load for 1 hour - 300 Ah.
If you want to use it on full load for 2 hours - 600 Ah.
If you want to use it on half load for 1 hour - 150 Ah.
And so on.
Jul 18, 2010 | PowerBright Power Bright PW3500-12 12 Volt...
I have three Toshiba Satellites, 2455-s305 (an older model with desktop P4, 1G Ram, XP pro, etc.)They boot and run, but have problems: (1) When turning this one on, I must press the power button, then...
turn off- unplug power- remove battery 1minute replace batt power cord press and hold zero restart while continuing to hold zero 30 to 45 sec screen will flash when you see cursor blinking let go... now you will have option to restore to (out of box state) select each time.( finish when prompted) computer will restart several times DO NOT TOUCH MOUSE OR KEYBOARD until you are sure auto config is thru approximately 1 hr 45 min
Sep 26, 2009 | Toshiba Satellite 2455-S305 Notebook
I just put a new screen in my dell 1501 laptop and
Thats because, screen or inverter was from different laptop or not compatible. For Dell laptops you have to buy screens with inverter together by dell part number.
You should be happy if it's bright enough. There is nothing else to do or try different screen or inverter.
Jul 08, 2009 | Dell Inspiron 1501 Notebook
Compaq FP 7317
I'm not sure about the inverter part of this but have you checked the menu options on the monitor itself to be sure the brightness and contrast haven't gotten messed up? Sometimes as a monitor gets older it requires more brightness to look the same.
Mar 28, 2007 | HP Compaq FP 7317 17" Flat Panel LCD...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
