Question about Microwave Ovens
The black handle snapped off have ordered a new one How do I replace it? Frigidaire Model FMV156EMA Thanks
  • Microwave Ovens Master
  • 9,047 Answers
A similar model's service manual can be found here, and that will help you with disassembly.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Aug 20, 2010
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
Model# FMV156EMA over the stove microwaive. We set the timer and when you push start the light on the inside comes on, but the microwaive will not start, the timer also runs but it does not actually come...
You have a failed bottom door switch, or that switch's mount is broken or misaligned.
See the service manuals here and here and this text file.
Jan 22, 2011 | Frigidaire Microwave Ovens
Fridigaire over the stove microwave. the handle is broken. We can order a new handle but don't know how to install it. Can you help? thanks, Linda C. e mail ...
You must take the door out by removing a screw then lifting the door off the hinge pin then the door must be laid on it's front and, completely
disassembled to replace the door handle.
Aug 13, 2010 | Frigidaire Microwave Ovens
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 16, 2009 | Microwave Ovens
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Replacing Handle on GE Microwave # JVM2070CH02
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
Jul 04, 2009 | GE JVM2070 Microwave Oven
Our handle broke off our GE Profile Spacemaker Oven
You can easily perform this repair on your own and save the cost of labor charges and a service fee. Go to appliancepartspros.com and type in the model number you provided. The door handle is located under Section 1 as item number 1801. Make sure you order the correct color.
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
May 12, 2009 | GE JVM1490 Convection/Microwave Oven
How do you change interior 20 w lamp?
remove the 3 screws on the vent above the door. Next unplug the oven from the power source.Next you will see a single silver screw above the control panel..remove it and slide the control panel upward and out. This will give you access to the lamp socket...turn it left or right and pull slightly ...you can now unscrew and replace the bulb....It was my exp that the lamp got loose in the socket from slamming the door after about a year, and I only had to tighten the bulb..Hope this solves the problem...Jerry
Mar 19, 2009 | Frigidaire FMV156EM Microwave Oven
Broken handle
Almost all microwave ovens manufacturers locate the handle mounting screws behind the inner black plastic frame known as the 'choke'. If done very carefully, the choke can be removed with a putty knife without breaking it. My suggestion would be to order a handle and a choke. HOWEVER ordering a complete door will be less aggravation and not a lot more money. The handle and choke will cost around $120.00 whereas a complete door goes for around $130.00. Check out www.searspartsdirect.com for more detail.
Feb 03, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave door handle
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
