Question about Dewalt 7.2-18.0 Volt One Hour Charger
When the DeWALT DE9118 charger is plugged in there is no power getting through the power light remains off - have checked the plug fuse no joy - please have you any ideas?
    Novelist:
  • 99 Answers
It sounds like you need a new charger I'm afraid. If you want to double check though, take the housing apart (4x security torx screws in the underside corners) and check the little glass fuse on the pcb. If either main fuse or glass one is blown you have a problem with the board and it's not worth repairing. If both fuses are ok I would suggest you might have a dry solder or broken leg on one of the pcb components. You could possibly resolder it if you can find it and it has enough contact left.
Posted on Aug 22, 2010
Delta CL 180 model charger turns on when you plug in and the yellow light comes on but when you put the battery in to charge the lights go out?
If all lights go out after the battery is inserted, the charger has entered pre-charge mode. In approximately 5-10 minutes, the orange and red lights should turn on indicating that fast charge has been initiated. If all lights remain off after 15 minutes, remove the battery. The orange light should glow. Reinsert the battery. If the orange light goes out when the battery is inserted and all lights remain off for 15 minutes the battery should be replaced.
Hope this helps.
Apr 09, 2012 | Dewalt Drills
I have not used my go.go elite traveller plus for several months now,and when i went to switch it on the battery light would not come on.I have tried charging the battery and the power light illuminates...
Ann You probably have a problem with the charger and your batteries. If it has sat for several months and wasn't charged during that time the batteries are too low to be charged and the charger cannot pickup the charge on the batteries. Now check the charger to see if it has a fuse if it does check the fuse to make sure it is good If the fuse is ok then if Charlie has a voltmeter he cqn check the output of the charger at the 3 prong plug set the meter to 200 volts dc and touch the 2 outter pins of the plug careful not to touch the barrel of the plug. the voltage should be 27+ volts output. If you aren't getting any reading then the charger needs to be replaced. Hope this helps
Mar 21, 2011 | Universal Power Group 24V 5A Universal...
No signs of electrical power. The vertical orange light is off.
try plugging into a seperate wall socket if no joy the charger may need peplacing i would suggest ebay. but try the socket first.
if it isn't powered by a charger and plugs directly into the mains try the fuse in the plug.
Oct 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
Have just got the Dewalt DE9116 charger.Plugged it in & red light comes on & then goes off.Is the charger working properly?Have no instructions
that is normal it happens when u plugged and unpluged. after a second it should show no blinking. then when u insert the battery pack it would show the diagnostics. with the blinking pattern.
if you need the manual , you can get at www.dewalt.com or call us at 407 657 0474 and we can fax it to you.
Sep 23, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Aug 06, 2009 | Dewalt DC011 AM/FM Radio
My dewalt radio stopped working. I plugged it in, no power. I charged the battery and put the battery in and no power ?
Check fuses inside. Check fuse and connections in plug. If this is a 110v radio there is one on transformer winding.
Jul 17, 2009 | Dewalt DC011 AM/FM Radio
Charger/power light will not come on when plugged into usb or car charger
Check the FUSE usually located in the plug if so equipped try owners manual. Also check car fuse for short or overload fuse opens, also bad battery replace it, try Mouser electronics lotta techs are ordering on line no min order.
Apr 16, 2009 | GPS
De walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Aug 07, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Dewalt 7.2-18.0 Volt One Hour Charger Logo
1,530 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
