Question about Fujitsu Siemens Computers & Internet
Hi. I have problem with Fujitsu Siemens P19-2. When I turn the Pc the LCD stey black, but the led indicate the it goes on, back light is on too. But lcd is still black (use DVI). When i plug laptop on VGA it is same. After I open the lcd it stars work. In past it sometimes happend but after swith on of PC it goes on. Now it stey black util i open it. Have you anybody heard about it, pls? Sorry for my bad english. .
Please read this article http://rcm.mwft.org/en/kludge/lcd-monitor-repair.html
It shows to bad capacitors in power supply !
Posted on May 06, 2011
  • xyzxx May 06, 2011
    Ooops ! That is not exactly the solution for this problem. Sorry. This is for another problem decribed here on this site.
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Hello , everyone and experts people. I have a Fujitsu Siemens Esprimo Mobile V5535. laptop good start, green LED lights up, but i have a black screen without any background applications. I tried to pick...
Hi dejandan1
Sorry to hear you are having problems. The very fact you tried an external monitor shows you have some good IT skills. As long as you know this monitor works it is a good test. As you have no image try toggling the video output signal by using Fn (Function) and the CRD/LCD (Cathode Ray Tube/Liquid Crystal Display) keys or Alt (Alternate) and the CRD/LCD keys.
If this does not workthen it is either
1. Laptop on board graphics failure
2. Laptop LCD panel failure
3. Laptop inverter failure
4. Laptop backlight failure
Turn on your laptop and look closely at the screen, can you see what you would normally see but very very dark? If so it is the backlight. If you cannot see anything, which is likely, then it is the inverter, actual panle failure or grahipcs chips on the motherboard.
http://www.daileyint.com/hmdpc/lcd.htm
philswift.gif Above is a link and flow chart that will help you.
It is most cost effective to send or take the laptop in for repair. You can replace inverters yourself but there is guarantee it is that. If the graphics on the motherboard has failed then all you can do is have the motherboard replaced. If the laptop is slow and old it may be time to consider a new laptop. If the laptop is under warranty, goto the Fujitsu Siemens website and log a under warranty repair.
All the best, Phil
Dec 06, 2010 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu siemens amilo li 1705 LAPTOP FAN TURNS LED LIGHTS BUT HAVE NO DISPLAY
fan keeps turning or turns off right away?
have u tried taking memory out and putting back in?
if so could be lcd or processor
Nov 25, 2009 | Dishwashers
What does blinking red led on front of tower indicate?
It Indicate that your PC is processing request by using CPU
Oct 15, 2009 | Fujitsu Siemens Celsius R610 PC Desktop
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
Indicator LED blinking, no display on Fujitsu Siemens L19W-2
I've got the same situation. I think it is old enought to break. I just can't turn on the light behind the screen.
Jun 15, 2009 | Fujitsu Siemens Business Line E18-1 18.1"...
Power goes off when booting ...
Hi if you had not used your notebook for sometime and kept it without charging the batt., then charge the batt fully probably for 12 or 14 hours and then switch it on .
May 24, 2008 | Fujitsu Siemens Lifebook C2230 Notebook
Computers & Internet Logo
1,170 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
