Ridgid 2 12" Angled Finish Nailer R250AFA  NEW Logo
Posted on Aug 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The gun will fire but the plunger will not retract back up into the chamber.
Clark Shull
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2017
Clark Shull
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
298
Points
Make sure that the cylinder ring is in the groove with tiny holes.
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Aug 24, 2010
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563650
Points
12312
This unit likely needs oiling +/or O-rings. See the link below and enter your model number to get a complete parts breakdown diagram. Focus on the o-rings for the main plunger assembly.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJj0yNXm0qMCFZxo5Qod9QMmug
1helpful
Dewalt 51845 nailer
plunger is eiyher nicked or bent. check for any small nicks that might be on the plunger, if so carefully file the nick so it is smooth with the rest of the plunger
Bostitch nail gun
You should be able to find parts for your model nailer doing a simple web search. Take out the allen screws on the back of gun, remove the back, inside the chamber you'll find a round metal disc, this is the plunger, the drive pin is attached to the other side, the plunger, and pin is one piece, when you remove it you'll see where the pin has broke off.
I have an older gun can't read any specs the lables are worn off, the guns safety plunger is sticking allowing for free fire of the gun. most of my other guns have a step plunger with the spring r
To find the model number, look on ebay for hitachi framers and hopefully you will find one listed that looks like yours. If no joy, take the gun to your local fastener/nailgun dealer for parts. The dealer most likely has box full of used parts for your gun. I have seen many older nailers with bent safety foot that caused the plunger to stick in the engaged position. Some nailers have the safety return spring incorporated within the trigger plunger /valve area and still others that have the spring hidden under a guard on one side of the nailer (guard part # 883493). Look under the main body of the nailer for an indention where one side of the safety spring fits into (less than 1/2 inch in diameter) ; directly below the indention will be a point on the safety foot to catch the other side of the spring. Good luck
6helpful
Stampede ECS won't fire the darts. It sounds as if it is firing, however, the darts just stay in the chamber. The spring mechanism is moving and the batteries are new.
I had this same problem. Well, actually after I modded it. I hope you are good with your hands, because this takes effort.
Unscrew the casing and open the gun (remember to take the battery pack out and have the two plates together so that the wire connecting them doesn't break).
When you see the plating covering the plunger (spring) system take it off, it has about 5 screws.
Since this is extrememly hard to explain in words, look at an internet picture of the internal plunger system. The way it works is that when the spring/tube goes forward (as the motor operates) the 'plunder' (the white thing) stays back. As the orange tube goes forward it triggers and release mechanism that fires the plunger forward due to spring pressure, compressing the air, therefore firing the bullet.
All you have to do (which is what I did) is insert a clip (with the plates open), make sure the jam door is closed, and put the battery pack in (to complete the circuit). Do a bunch of test runs to make sure the white plunger is shooting forward as the mechanism operates.
This will all make sense once you activate the gun without base plates.
Email me at [email protected] if you complete it, have questions and/or comments.
I hope it helped!
PS- while you're at it, you might as well look for online instructions on how to mod the air restrictor (as I am too lazy to write a few more paragraphs!).
2answers
Having problems with the gun not pulling the next nail, the thickness of the wire between nails sticking in gun and then double shooting. using gun in new england, its cold we warm it first. any...
Nail feeder on this gun is both air and spring controlled. Air pressure retracts the feeder and a strong spring pushes the feeder back to front. Remove nails and leave side door open. Dry fire gun very rapidly against thick rubber pad and watch the feeder retract and return. It should move very rapidly all the way back and front again. If it appears to move slower than piston is moving then follow next step. Pull the feeder back manually with tip of screwdriver. It should be very hard to overcome spring. If spring feels strong then suspect feedpiston oring or air supply to feedpiston chamber is restricted with debris from inside of the gun housing or air is leaking where body of gun mates with lower nose. There is a small white oring that seals between body and nose base. Sometimes this oring will be over-compressed thus restricting air flow into feed chamber. Remove two allen screws at front of base to split body from base and reveal this oring. Parts are available at www.toolpartsdirect.com. Good holidays
1helpful
My T50P will not discharge staples. I'm using the correct staples, there is no jam that I can see, and everything is well-lubed. It seems like the driver is not retracting far enough to allow a staple to...
sometimes mine won't shoot, and i find a single staple in the track, almost ready to fire out , but can't , they can be hard to see in the tract, i keep sharp pliers on hand to clear them. hope this helps
5helpful
Paslode (30 degrees) framing gun firing pin not retracting
The tool needs to be completely torn down, cleaned out, two orings inside need replaced, re-lubed and re-assembled. takes a technician about 1 hour to do it right. I believe either the orings or dirt is your problem. If blade doesn't return its probably the orings.
Plunger want retract
The hammer could just need to be oiled or you could have blown a seal in the gun which is not expensive to fix around 20.00 . A lot of times when my gun jams on a nail it gets stuck so the hammer won't go down. I just use something thin that will fit on the hammer and take a hammer and just tap it back into place.
Top Ridgid Air Tools & Compressors Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Ridgid Air Tool and Compressor Expert? Answer questions, earn points and help others
