I keep getting a couple of streaks across my printed image, as if the ink skips over these areas. I've tried cleaning and realigning the heads, as well as printing with the high speed printing mode turned off. Any ideas?
    President:
  • 1,138 Answers
A problem with the ink cartridge.
Sometimes, after some refills with the cartridge and those resets procedures for the printer to stop detecting the ink volume... the cartridge really will be on its last leg.
If after flushing the ink cartridge in a tap water and soaking it in a mixture of ammonia and water will not clear the print head of the cartridge to let the ink out proportionally..... the very last option is to replace the cartridge with new one.
I hope that helps.
Thanks
Posted on Aug 19, 2010
Horizontal White Lines
My 1st thought would be clean heads also. If ink is tanks only not heads take ink out and try cleaning heads with liquid cleaner available @ Staples or similar stores. Another fix might be to use alignment utility for your printers software; however before you do any of this if ink is old or nearly empty replace ink.
Jun 13, 2013 | HP OfficeJet V40 All-In-One InkJet Printer
Black ink blobs, streaks, and dots
R350 type my printer,not respont end error in display
Nov 28, 2012 | Epson Stylus 1400 InkJet Photo Printer
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
Canon PIXMA MP510 : When I print something in colour, I get alternating dark and light 3mm lines printed horizontally down the page. I've tried cleaning, deep cleaning and realigning the print...
Hello
what you need is to clean, you need to clean the prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easily clean ink cell.
Jun 29, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Epson Stylus R1800 is not printing correctly. It is skipping spots leaving clear areas across the page. Changed all the cartridges.
your problem is not with the inks it is with the printhead... try running the maintenance and head cleaning... epson is notorious for print heads getting clogged!! good luck
Mar 31, 2010 | Epson Stylus Photo R1800 InkJet Printer
Horizontal streaks across printed pictures
Did you run a clean heads from the menu?
Also there is a function to align the heads again as well on the Menu
Feb 17, 2010 | HP PSC 2410 All-In-One InkJet Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
I have a epson stylus 660 i am trying to print
A full cleaning of the head requires removal from the printer. The "cleaning funtion" will still leave dribbles on the bottom of the head which cause streaks. SOMETIMES you can wet a couple thicknesses of paper and drag under the heads to clean the area. Use 91% isoprophyl alcohol.
If the ink has bled out of the heads it takes a lot of patience to get the ink cleaned out. Also the paper rollers often need cleaning.
Sep 22, 2009 | Epson Office Equipment & Supplies
Black Ink Skipping
After entering my posting earlier today, I did some more internet searching on this problem. I found a helpful British website that listed a trick for cleaning the printer carriage area. It's a little more than halfway down the page, if you click on this link, http://www.valueshop.co.uk/printing.asp
Here is what they suggested:
"1. OPEN printer so the cartridges move to center of the carriage.
2. REMOVE all cartridges.
3. FOLD a letter size piece of paper in half, and then in half again the other way so it is quartered.
4. START with the long, folded edge and insert into front of printer where paper normally feeds out. (it will slip in a little over halfway)
5. MOVE the paper left and right to remove any excess ink under the carriage. When the excess ink is removed the printer should print streak-free. "
I tried this (actually used 3 or 4 pieces of paper because it was pretty grungy), and I can print without bands of gray now. Although, the colors are not as vibrant as they used to be, neither is the black. (My holiday newsletter looks good enough to send out, at least.)
After cleaning the printer carriage area, I ran the nozzle check pattern test again and it still looks bad. I then cleaned and realigned the print head, and again the nozzle check pattern continues to look bad. The user manual for the F60 (page 10-5)said that if the nozzle check pattern does not improve after a deep cleaning then the printhead may be damaged. I called Canon tech support and they think that the printhead is probably damaged, but they suggested that I take it to an authorized Canon repair shop, which is too far away, and probably too much trouble. My other option is to order a new printhead directly from Canon for $45 plus $6 shipping and install it myself (or make hardware engineer hubby do it ;-) ).
Hopefully this trick for cleaning the printer carriage area will help others at least for the short term, like it helped me. Good luck!
Oct 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
46 people viewed this question
k24674
