Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
I have Malibu ml100 and the lights came on erratically and now don't come on at all. When I touch the menu button nothing happens - it is getting electricity as pump on same circuit is working.
I have a model 8100-0300-01 . The dte is H1612. My low voltage lights don't come on anymore. I have pressed the reset button but nothing happens. Can you help me?
Copy following link and scroll down to identify low voltage timer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
This particular line of Malibu timer has 1 year limited warranty.
Don't buy digital, photoeye timers for outdoors.
See if you can set timer so lights are ON all the time, then plug power pack into cheap wall timer.
Mar 26, 2013 | Hardware & Accessories
SAMSUNG ST95: WHEN I TURN IT ON THE TOUCH SCREEN IS BLACK WITH CURSORS ON IT(^V) ALSO SAYS SAMSUNG AND MENU AND OK ON IT. iT IS COMPLETLY FROZEN AND DOES NOTHING.
9_28_2012_7_46_40_am.jpg ST95 SAMSUNG CAMERA
THIS IS THE PROBLEM WITH MY CAMERA I NEED SOME HELP FOR THAT WHEN I OPEN MY CAMERA ITS SHOW'S THIS THING AND THEN I TRY CLICKING ON OK AND MENU AN BUTTONS BUT NO THING WORKS IF I TAKE OUT THE BATTERY AND PUT AT IN AFTER ONE DAY THEN ITS OPEN BUT IF I TURN IT OFF AND TURN ON AGAIN OR IF I TRY TO TAKE A PICTURE WITH IT LENS COME OUT AND THEN GO BACK AND THEN ITS TURN OFF IT SELF NOW IF I TURN ON AGAIN ITS SHOW'S THE SAME PROBLEM I DON'T KNOW IF ITS THE SETTING OR WHAT PLEASE HELP ME THANK YOU.
Jun 21, 2012 | Samsung ST95 Digital Camera
I don't know what happened but ipod does nothing. tried resetting (menu & select)(menu/select & select/play) not sure what else to do. plugged into computer and still nothing. please help
Welcome to Fixya
Try resetting the ipod by pressing the middle button and the menu button at the same time for 5 to 10 seconds. The ipod logo should appear after the reset has done.
Thank you for using FIxya!
Oct 02, 2011 | Apple iPod classic MP3 Player
On my prs-600 I press the forward arrow button once to go to next page but pages start scrolling by rapidly as if button was being held down it won't stop until I toggle power slide.
maybe?: My touch was acting oddly. Page-turning was erratic (almost like a sticky key). Sometimes nothing would happen, other times near normal, but often flipped through large number of pages & was unstoppable. Cleaning button area (under / around / in-between) did not help. As I was about to smash the infernal thing to bits it dawned on me... try a reset (see manual under troubleshooting, p 151-152 approx. Has been fine ever since (couple of months daily use).
Sep 20, 2010 | Sony Reader Touch PRS-600
My unit is a malibu 100 not 300, program does not work
Open following link for ML100 manual from Intermatic.
Read the section about Mode.
Please add a comment with more questions and I'll work alongside you to figure out problem.
For more information on Intermatic/Malibu power packs showing replacement trippers, useful links, warranties and tips:
http://www.fixya.com/support/r8391011-power_pack_not_working
Feb 08, 2010 | Intermatic Malibu 300W Power Pack...
How do i reset my sansa e270
Press and hold the "Power/Menu" button for 15 seconds to reset it back to its original factory default settings.
Sep 24, 2009 | SanDisk Sansa e270 MP3 Player
Main menu screen problem
I think the degitizer (touch screen ) is faulty.
Replace it.
May 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Touch screen does not work
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Mar 22, 2009 | Leapster Learning System
Screen is frozen
Are you saying that nothing at all happens every time, or sometimes you get the wrong thing i.e. you touch Prog and Rep screen comes up? Have you ever recalibrated your screen? This should be done regularly - at least every six months, but I do mine monthly. The catch is that in order to do this, you need to access the Set Menu and if your screen is not responding at all this would be impossible. In the Set Menu on the last page (I think) there is a "Color Touch Screen Adjust" button. Use this to access the calibration screen, and you must touch exactly in the centre of the two crosshairs until they turn green. Instructions are on Page 31 of my manual.
Dec 26, 2007 | Husqvarna Designer I
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
121 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
