Question about Sanyo 18KS52 Air Conditioner
THE REMOTE CONTROL HAS NO READOUT, THE NUMBER ISRCS-1HPS4U-G. THE UNIT WILL RUN IN TEST MODE, BUT NOT WITH THE REMOTE STAT, IS IT SHOT
Readout says "HOT". fan stays on. Unit is not hot. Disconnected fan to save battery days later reconnected and still same. Is there a bad sending unit or T-Stat?
On a 2004 Sportsman 400 there is a sensor on the left side of the engine head, just under the thermostat housing. If that sensor is bad or disconnected the hot lamp will come on which causes the fan to constantly run. Good luck and if you need any more assistance let me know, Daniel.
Oct 27, 2012 | Polaris ATV
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
Unit doesnt shut off. Even when I turn off the power switch it still runs. When in energy saving mode it does the same thing. I have to unplug the unit to get it to shutdown completely. ????????????????
Remove the cover to the thermostat to get to the control wires. Now remove the red wire from the stat. If it shuts off, the stat is bad. If it continues to run, the 24 volt hot wire from the stat to the unit is touching the cooling or heating wire somewhere from the stat to the control section of the unit. You can also disconnect the stat wires at the unit to prove this. You will need to pull a new set of stat wires to your unit, or if you have a extra wire not used , find the bare one that is touching, and use the spare wire in its place.
Shastalaker7
A/C, & Heating Contractor
Feb 18, 2011 | Heating & Cooling
When i press the remote all i get is DVD 3
Your player has been set on remote mode 3, you need to change remote control itself on remote-3 so unit can get remote signals.
Set the command mode for the remote so it matches the command mode for the recorder.
Hold down ENTER.
While holding down ENTER, enter the command mode code number using the 3 number button.
Hold down both the number buttons and ENTER at the same time for more than three seconds.
Remote control has been set on mode-3, now player will accept remote commands.
Hope this will help you.
Thanks.
Nov 24, 2010 | Sony RDR-VX525 DVD Recorder/VCR
We just purchased a ge profile refrigerator today, and cannot get it off of demo mode
You have to go into the Diagnostic mode to see if you can reset this issue or if the main board in back is bad. Here's how to do it:
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
First, run the control and thermistor test:
Control and Sensor System Self-Test (0 7)
This test checks all five thermistors located throughout the unit. Once the test is initiated, the test code (0 7) will stop flashing and the thermistor test results will appear on the freezer display in the test order listed below. The thermistor test sequence number will not be shown on the display. If the unit is not equipped with the Quick Chill option, the third thermistor (quick chill) will display a 0 and 3 audible beeps will sound at the temperature control panel. This is not a failure if the unit is not equipped with the Quick Chill option.
Thermistor test results:
• P = Pass
• 0 = Failed
• S = Short to 5 VDC
• B = Bad amplifier
When testing has been completed, do the following :
• Enter code 1 5 to completely reset the system. Then press the Hold button (or any other button than a temperature button) to accept the code.
When you're done, unplug the refrigerator for 10 seconds and plug it in....if it does not run, the board is bad.
Jun 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
RV A/C COMPRESSOR RUNS CONSTANTLY
You must isolate the problem by disconnecting the thermostat wires that go to the unit. If the compressor does not run when the t-stat wires are disconnected, that shows that the t-stat is malfunctioning, or there is a short in the wiring between the t-stat and the ac unit.
If the unit continues to run after disconnecting the t-stat wires, then you'll have to look in the unit for a stuck relay
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Xm2go direct entry tuning problem
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Nov 15, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Remote control not working
have you program first the remote control, to work on your TV..??
Heres a few instructions how to programmed your remote..
  1. Test your remote control. To find out whether your remote control can operate the component without programming, turn on the component such as a VCR and press the corresponding MODE button (VCR) on the remote control, while illuminating on the selected component. Test the POWER button to see if the component responds properly. If not, the remote requires programming to operate the device.
  2. Turn on the component to be programmed, then press the corresponding MODE button on the remote control.
  3. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control. At a moment, you have to repeat from step 2.
  4. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming code numbers for the corresponding component can be found on the following pages. Again, if the code is correct, the device will turn off.
  5. Press the MENU button to store the code. After blinking twice, this code is stored.
  6. Test the remote control functions to see if the component responds properly. If not, repeat from step 2.
Try 001 as the PCode.
Thanks..
May 08, 2008 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Sanyo 18KS52 Air Conditioner Logo
55 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
