Question about Hotpoint Microwave Ovens
Can you install a hotpoint hot GD741 with a flexible hose
How can I get a copy of the manufacturer's installation instructions for a Hotpoint JX-81J over the range microwave oven?
JX-81J is the microwave recirculating charcoal filter for several models of GE and Hotpoint microwaves. The installation instructions will be available from the manufacturer with the model number of the microwave itself.
One microwave that uses this filter is the RVM1535MMSA . See http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=HPSPECPAGE&Sku=RVM1535MMSA#tab1_ for all of the details on this microwave. The owner's manual, http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40541-1.pdf , shows the installation of the filter on page 34. The guide for installing the microwave above the range is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=39-40425.pdf .
If you have a different microwave, add a comment with that model number. I hope this helps.
Feb 13, 2017 | Hotpoint Microwave Ovens
My hotpoint oven lost all power while cooking
Might be a fuse inside, or the unit may have died. Contact the manufacturer and keep the unit unplugged.
Feb 13, 2013 | Hotpoint Hot Point - RVM1535MMSA Cooking...
How to start oven in rmv1535 model microwave
You can download GE owner's manuals and installation instructions here.
Dec 25, 2012 | Hotpoint Hot Point RVM1535DMWW Over the...
I have a new hotpoint microwave and it completely shuts off after 3 minutes and in a minute or 3 later it turns back on
First if it is brand new it has a warranty---call Hotpoint customer service or even take it back where purchased for exchange or repair.
Oct 21, 2012 | Hotpoint Hot Point RVM1535DMCC Over the...
I have installed the muirfield model kitchen faucet. I attached the water hoses and I am not getting hot water when I turn to hot. I am only getting a trickle. bith my hot and cold water is turned on all...
You are going to have to take the line off again and check it for debris or any plastic guides that have slipped out of place. You may have an internal clogg caused by something getting into the hot side of the faucet. Check any screens on the faucet for pluggage.
May 06, 2011 | Microwave Ovens
THe vacuum comes on, but very little suction. We have check the wand and flexible tube, but there is no obstruction. This vacuum was donated to our auditorium and we have no manual. Does Sears repair...
You do not state the make or model of the vacuum cleaner. Assuming it has a hose, try disconnecting the hose from the machine. You may find your blockage there.
Mar 26, 2011 | Microwave Ovens
I have a Hot Point overtherange microwave that I am trying to install. Unfortunately I don't have the screws that secure it to the above cabinet. Hot Point itself can't tell me the size of these screws. ...
Depends on what you are screwing it to ,use metal screws as in sheet metal and get as beefy as you can that fit through hole . I would predrill any holesslightly smaller than the screw to make it easy n ya .Just know where the tip of the scew is going ,not through an electric line or clear through the other side
Feb 18, 2011 | Hotpoint Microwave Ovens
Hotpoint bd35 electric oven instruction manual
Here is a link for you to download a PDF instructional manual for your Hotpoint cooker or Hotpoint oven.
how to use this service
1 click on Link,
2 click manufacturer (Hotpoint)
3 enter your model number and download the PDF file .
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Jan 28, 2011 | Microwave Ovens
Hotpoint RVM1535DMCC OTR micro-has NO stove top draft.
Did you check the installation instructions and the owner's manual?
here.
If you still have a probme, I would call the GE Answer Center:
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
Mar 05, 2009 | GE Hotpoint Over-the-Range Microwave
Microwave Ovens Logo
32 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
