Question about Welding Tools
Looking for schematics for thermal arc 400 gms welder
2 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: Thermal Arc Welder 150 GTSW went ''pop''
You badly need a service manual, you might be able to get one at the Thermal Arc home page.
Since it blew the input power breaker and let off a bit of smoke we'll take as given that something in there shorted. Inverter welders like this have a rectifier section, then an inverter section, then another rectifier section before the torch. I'd bet a little money that what went pop was one or more of the SCRs in the rectifier section. You really need the manual to do anything useful to this machine, pay particular attention to the repair sections where they talk about cold checks before powering the machine on again, it'll save you hours of replacing parts.
Please rate my answer,
Carl
Posted on Dec 03, 2008
How do I troubleshoot a chicago mig-100 welder fuse keeps you
Looking at a owners manual with a parts list and schematic, there is no fuse in your welder. There is a thermal overload switch that senses overheating and shuts your welder down. If it is stressed to its limit it will not function any longer. Try going to the place of purchase and see if they can supply you with a thermal switch.
Mar 02, 2015 | Welding Tools
Repair mig welder
Control circuit failure or blown fuse on low voltage power supply. Look for 24VAC transformer. If that is OK follow to the trigger contactor and see if it is disconnected, burnt, etc.
Aug 28, 2014 | Welding Tools
Require schematic for canox c-sw350 welder
Since most operate on the same basic principles, the motor control should use a simple pair of SCR's to drive the wire feed and speed. They are often a weak point as most are just 200 volt 8 amp standard sensitivity types. A standard Gate 400 volt 10 amp type gives a margin of reliability without costing much more, and sometimes less.
Various vendors sell them,
Dec 16, 2011 | Welding Tools
I have a Lincoln 120v wire feed welder, model 140, and while welding, the gun cam unplugged and it arced a little on the plug end, and now, the fan runs, but nothing else will happen, it has been two hours...
Check your switch terminals, if they are connected and everything looks good, then unplug the terminal and bridge the connector (bypass it) if it start turning your drive rolls then your switch it's damaged, if nothing happens then you burned the pc board.
Dec 08, 2010 | Welding Tools
I have model 91811 chicago electric inverter. worked fine last time I used it,,, now it won't work. fan comes on, as well as power light, but will not arc.
Can you hear it "humming" inside. If not check fuses / wiring connections inside case. Failin gthat sounds like transformer has failed.
Feb 24, 2010 | Inverter 220 Volt Tig Arc Welder
Wire won't feed or arc fan runns
Look for a reset button on the case. Make sure that you have power to the machine and at the power socket. If everything looks ok outside, you may have to investigate your warranty. Good luck!
Jan 04, 2010 | Miller matic 140 Mig Welding Package W/As...
Solar welder 2175 wire keeps feeding wont stop doesnot arc until trigger is pulled
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Dec 14, 2009 | Welding Tools
Carl
Nov 15, 2008 | Welding Tools
Welding Tools Logo
224 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
