Question about Samsung RFG297AAPN (29 cu ft) Bottom Freezer French Door Refrigerator
A black metal bar the lenght of the drawer width (~2ft) fell off after I opened the freezer drawer. It looks like it fell from the top drawer. The shape is square and there is a peg attached to it on the one end only. So far (two weeks) I haven't noticed anything not working Any idea where this should be attached?
How do i switch drawers what release is on glides
if this unit has the kind of slides that are metal and use small barring balls to slide the drawer, look for a little black plastic tab or lever one pusher down and the other one pushes up. pull drawer while pressing on tabs.
Dec 17, 2014 | Baby Cache Kensington Double Dresser -...
All i need to know is how do u convert 9ft lenght x2ft wide x 2ft high into cubic meter thank you
Multiply 9ft by 2ft by 2ft to get 36 cubic feet. One foot is exactly 0.3048 meters so one cubic foot is about 0.0283 cubic meters. Multiply that by 36 to get about 1.019 cubic meters.
Oct 18, 2013 | Office Equipment & Supplies
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
Door handle of my Amana freezer drawer fell off on one side. Screw is inside the handle. How do I fix? AMANA ABL2227FESThanks
It looks like the silver handle is pushed onto the black plastic insert, which must be removed from the handle, fixed to the door and then the handle reattached.
Feb 07, 2013 | Freezers
My bottom freezer not closing properly
Pull both drawers completely out of their locations, clean off the slides that they each normally rest on. Clean off the surfaces beneath where they sit. Now, if they are both the same width and height, switch them and see if the problem is solved. If not, check the actual drawers to see if their sliding surfaces are cracked or covered with any kind of junk. You should be able to get everything to fit with these procedures.
Jan 12, 2013 | Maytag MFD2560HES Bottom Freezer French...
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
When the refrigerator defrosts, the water does not make it down to the pan to evaporate, water is dripping down on top shelf and under crisper draweres...how can I find the area to find a clogged up line?
The drain line is located in the freezer compartment. Remove the contents of the freezer and take the back panel off. Once the panel is off, you should see the evaporator coils. The drain is located below the coils in the center. Remove any dirt and debris around the drain opening. Use a lenght of wire and insert it down the drain tube to clear it from any blockages. Pour some warm water down the drain opening and check it flows into the drip pan below the fridge. Hope this helps you.
Mar 09, 2011 | Refrigerators
A toolbox is 2ft. high and its width is 3ft. less than its lenght. if its volume is 80ft.
We find volume by using V = H*W*L , where H = height , W = width, and L = length. You say H = 2 ft,
V = 80 ft ^3, and W = L - 3 . Put all of these back onto the equation and we will have
80 = 2 * (L - 3) * L . We can condense this to be 80 = (2*L - 2*3 ) * L then becomes 80 = 2*L*L - 2*3*L
simplifying this we get 40 = L*L - 3*L . This is also 40 = L * (L - 3) this is a quadratic equation, meaning that
we will get two answers for L. In this case L = 0 and L = 3. Since 0 ft would mean that the tool box doesn't
have a length we will use L = 3. We can now put this back into our original equation to find out what the
width is. 80 = 2 * W * 3, this is 80/6 = W = 13.3333 . Now we know that W = 13.3333 and L = 3.
Mar 07, 2011 | Office Equipment & Supplies
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
Need Cubic Foot Capacity of this refrigerator please
Find a five year old child with a tape measure
and ask the child to measure the inside of the fridge
then width x lenght x hight = result
Then give child a lollie
Apr 16, 2009 | Refrigerators
Samsung RFG297AAPN (29 cu ft) Bottom Freezer French Door Refrigerator Logo
79 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
