Question about Microsoft Xbox 360 Console
Xbox 360 my xbox keeps cutting off while i am playing and start flashing 4 red lights
  • Alex Contreras May 03, 2008
    thaxz for ur help what is the best thing u will do if u turn it on sometime its 3 or 4 red lights on tell me p/zz i need to play the new game gta4?
    i turn it on right now and the 2 red light on the left and the one on the top of the right?
    Sniper:
  • 55 Answers
4 flashing red lights is a video cable problem. Unplug and replug the cable make sure it is snug. If this does not work try a new cable
If that still fails then it is hardware issue and we'd have to suggest some fixes from there. Let us know
Posted on May 02, 2008
  • Edward Stewart
    Edward Stewart May 07, 2008
    This is the 3 rrod and is actually covered under the microsoft warranty. If your console is no longer under warranty (that is you opened the console) try the link that dreckis604 suggests.
  • 77 Answers
Your xbox 360 is having what is called 3-Rings of death.. its bascially a short in the system when it heats up...are you still under the service warrenty?
call 18004myxbox it was extended to 3 years due to this problem. I would hope that you are.. but if your not there is still hope!!! depending on where you are lots of people can do a easy hardware fix for this.. check out the link
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
Flashing red lights
Your xbox might be overheating. Read http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907533&lcid=1033&category=hardware for more information.
Apr 10, 2009 | Microsoft Xbox 360 Console
Red lights flashing
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Dec 25, 2008 | Microsoft Xbox 360 Console
2 red lights
This problem may occur when the Xbox console is too hot or is overheating. The flashing lights mean that the internal temperature of your Xbox 360 console has exceeded acceptable temperature limits. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot.Verify that your Xbox 360 console has enough ventilation and that the fans are operating. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Microsoft can be contacted by finding the number listed on the back of your video game booklets.
Good Luck to you and Happy Gaming.
Source:
http://support.microsoft.com/kb/907533
Oct 17, 2008 | Microsoft Xbox 360 Console
Power cuts off
Might be a faulty power supply mate , when you turn the xbox on observe the power indicator on the power brick.
Green means its okay
Amber means the console is in standby
Red means the Brick has had it.
Try a friends power brick to see if it does the same.
jonno
Sep 03, 2008 | Microsoft Xbox 360 Console
3 then 4 red flashing lights
the lights let you know that your x box is not working correctly it is defective and you could also call it lights of destrution... what you need to do is call take the xbox back and inform them of this problem and they should have it fixed for you
Jul 26, 2008 | Microsoft Xbox 360 Console
Xbox 360
that means that your 360 is mest up and is impossible to fix if you get three red rings unless you call the 360 experts from company to fix it but i have to worn you that it cost alot
Mar 27, 2008 | Microsoft Xbox 360 Console
2 red lights
suddenly while you are playing you get two quadrants of the ROL (Ring of Light) around the power button of you Xbox 360 console flashing red, this is an indicator that your Xbox 360 console is overheating some how.
That will be due to one of the following reasons:
  1. You set your Xbox 360 console near to any heat source or electrical device.
  2. Your xbox 360 console is not set in a well ventilated area.
  3. There is something blocking the fan openings on your Xbox 360 console.
  4. You are using the Xbox 360 external fan, and basically that's a third party accessory so it sometimes harm the Xbox 360 console.
So, try eliminating all these reasons & if you are still experiencing the same behaviour then you have to contact Xbox 360 customer support to exchange your console or even to get it repaired.
Nov 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
