Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
No motor sound
Lifted it up to vacuum under it...........started making a rub-dub sound then motor quit...........only blue light is on now and it is not recognized thru My Computer..........is all lost?.......thousands of music files..........
  • jcrowther May 07, 2008
    stopped being recognized shortly after my motherboard was replaced. not making startup sounds or humming noises i'm used to hearing regularly, but the light still comes on.
  • Anonymous Jun 20, 2008
    I have a similar problem. Many times it does not turn up when I open My Computer.
    Other times it will show up but when you go into the files there is nothing there.
    If it is taken to be repaired will I lose all the music file saved on it?
    Sergeant:
  • 300 Answers
Can you say , WARRENTY , I knew you could :-)
Posted on Sep 11, 2008
My Sebo vacuum cleaner has no suction. Roller spins. If I leave it on it starts to overheat.
take it to a repair shop
something is jammed in the impellers section or the motor is burning out
Jan 05, 2017 | Sebo Vacuums
Cub cadet rzt 50 making grinding noise when starting after it starts still making noise sounds like coming from fly wheel. any suggestions thanks
The shaft that the solenoid pushes the gear up needs lubrication. If it's been grinding too long, the bearing in the starter is worn letting the armature to rub on the field frame. Might be time for a starter motor.
Oct 02, 2016 | Cub Cadet Garden
Dyson vacuum, Vacuuming when I sucked up some wires. I pulled them out and the vacuum started making a loud noise. Now when I use it that happens and now it sparks.. What should I do?
quit using it and take it to a repair shop sounds like your motor is shorting out. However i would suggest buying a new vac since dyson motor replacement can be quite pricey.
Mar 06, 2013 | Vacuums
Whenever i start dubbing a movie from sky movies on a dvd my picture always gets fuzzy
hi.
there is usually a signal embedded within movies which prevents the film being opied to DVD. on some recorders the picture will go fuzzy, on others the picture will alternate between light and dark picture. this is quite normal and deliberately done by sky to prevent people copying films.
Sep 06, 2011 | Vacuums
System quit working green light on
depending on the year of your machine, assuming it is the serenity blue, it may be the circuit board on the unit itself. The manual switch "should" start the machine, but if not it will be the circuit board inside the main unit.
however....
if your unit is the green one, it may be the motor inside the unit and/or the circuit board. Hard to say. I do not think that it is the motor as the circuit breaker should have popped out if it was the motor.
Regardless of the colour of the unit, if it is 5-7 years old or less, the unit should still be under warranty. home service calls and labour to install the motor would not be covered.
Good luck.
Nov 19, 2010 | Beam Industries 2775 Serenity Plus Central...
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
Was vaccuming and vaccum quit. Tried unplugging and turning back on. Getting absolutely no power. unscrewed screw under handle and tried to make sure connection was being made. Don't really know what to...
ok..If you have a multimeter you can check plug fuse then switch and motor, if you put leads across the plug you will get some reading if its working.could be thermal cut out on the motor.
Apr 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
I have a oreck xl2 and while vacuuming the vacuum quit. The vacuum has the red power light on. Please advise
sounds like a bad motor. if the light is on at the switch and the motor doesn't run, then it could definitely a motor problem, worn down or dirty carbon brushes. the motor on these machines are not the best built, they require cleaning of the commutator yearly.
Nov 18, 2009 | Oreck XL2200 Bagged Upright Vacuum
Dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
Oct 18, 2008 | Dirt Devil Purpose for Pets Portable...
They just stopped working!
Hoover has a 1 year warranty on their vacuums, so the newer one will be under warranty. The other won't be. It could be bad switches, even tho they sound ok, they could still be bad, One side of the cord could be open, there is also a thermostat on the motors, it may have opened up, then of course could even be the motor. Just would have to be check over.
Jan 06, 2008 | Vacuums
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
71 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
