Question about Epson Stylus Pro 4000 InkJet Printer
Getting a mnt req 0040 error - Epson Stylus Pro 4000 InkJet Printer
3 Suggested Answers
LHeruska
  • 94 Answers
SOURCE: I am getting an error message..Maintanence req.
a printer part will need to be replaced soon.
Here is a link to the manual for you.
http://ftp.epson.com/pdf/pro76u/pro76uu1.pdf
Posted on Feb 01, 2010
broyyce
  • 30 Answers
SOURCE: Epson 4880- gives error message MNT
This error code means that you have printed so many pages that it's time to get your printer serviced. Kind of how you get your car serviced after so many miles. I'd reccomend bringing it to the nearest printer repair shop. Most will just install a maintenance kit and reset the maintenence count. It will continue to print if you put off getting it serviced but who knows how much longer. It's better to get it done now before it craps out on you and you have to print something really urgent.
Posted on May 20, 2011
I am getting a MNT REQ. 0400 message. There is a W on the line below in the 4th space to right of the paper feed symbol. Sometimes if I turn machine off and on again I get a SERVICE REQUIRED 0001001B...
Hi Kate,
This is Randy. I've received your email and I'm working on a solution for you. You should be hearing from me shortly. I'm also reachable on the chat feature.
Thank you,
Randy
Jan 05, 2012 | Epson Stylus Pro 4000 InkJet Printer
I have an iomega lphd-up external drive it was working fine now it is saying that it needs to be fomated plugged in to several laptops i get the same message. i dont wanna lose the content. what can i do?
Try getting a live cd (such as the system rescue cd). Burn the .iso file to a disk, then boot from the CD by hitting a key at your BIOS menu (usually F1 or F9) to bring up the boot menu, and select CD. Once you've booted and you have your prompt, plug in your external drive and try the following commands:
fdisk -l (that will show you all the disks attached to your computer. Typically the first disk [internal] is sda, and the USB disk is sdb.) The thing to take note of here is the last column on the list that contains /dev/sdb#, it should say NTFS, or FAT32, or something like that.
fsck /dev/sdb1 (that will check the file system on the first partition on your external drive. If it comes back with an errory, try fsck.NTFS or fsck.FAT32, whatever the file system was in the first part.)
testdsk /dev/sdb (That will initiate a harddrive test that could find/fix errors with your drive).
If none of that works, plug in another drive to make a backup of your external. Take note that it's important to have free space on the SECOND (not broken) external that is EQUAL TO or GREATER than the amount of USED space on the broken drive.
Once the backup drive is plugged in, type mount /dev/sdc1 /mnt/backup (if that doesn't work or it says something about NTFS and read only, type umount /mnt/backup; ntfs-3g /dev/sdc1 /mnt/backup).
Finally, type mkdir /mnt/backup/SDB to make a directory to store the files.
Now with the second drive, try to mount it using the advice for sdc (although change /mnt/backup to /mnt/windows)
If it mounts, then type rsync -av --progress /mnt/windows /mnt/backup/SDB/ which will start copying all the files onto the backup drive. NOTE: This will cause a lot of text to scroll, and will take a long time!
Once that's finished, you can restart into windows and format your drive, then plug in the extra drive and copy everything back over.
Hopefully that helps!
Jul 20, 2011 | Computers & Internet
Epson 4880- gives error message MNT REQ 0088 on display
May 20, 2011 | Office Equipment & Supplies
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
Service required error 0001002d
Feb 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer is displaying message maintenance req 0040
refix the ink cartridge after clean .it seems like your ink need replacing.
Jan 09, 2009 | Epson Stylus Pro 7600 InkJet Printer
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Epson sp9600
aha and your printer is not functioning right now isnt it, or it is still operational, either way that error must be solve or you will never use your printer. this error means that your pump motor is near end about 5% of its life is left. here is the sure solution for your prob. turn off your printer then press the left, down arrow and enter simultaneously then power on the printer. inside initialize the sponge and cleaner then turn off and on your printer. note: you will have to replace your pump cap assy. if it is already poor in cleaning otherwise your printhead will suffer.
Sep 21, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 4000 InkJet Printer Logo
271 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
