Question about Kitchen Appliances - Others
Need the electrical schematics for a Decon fs300 ultrasonic bath to repair low power output.
4 Suggested Answers
  • 736 Answers
SOURCE: Please : Need power supply schematic Digitrex GKX
nearly all failures of this sort with power supplies are caused by billions of chinese made capacitors that are failing in just about everything .. look at the top of the electrolytic capacitors .. if its bulged up (should be flat) then thats your problem .. low average voltage is what you will get with an open filter ... the chinese somehow obtained the secrets on how to make the caps but didnt get the part about preventing electrolisis within the capacitor ..this produces O2 and H2 gases inside that eventually cause the case to vent or even rupture .. you will see modern computer mother boards bragging about the fact that they use only japan capacitors now ..
Posted on Aug 05, 2009
davesoucy
  • 148 Answers
SOURCE: botched repair
A good electronic shop should be able to fix this without schematic wich should be hard to find (nearly not available) for such machine. If the guy at the shop seems not sure, go somewhere else, this mean he's not experimented enough...
Ultrasonic bath is a music amplifier with speakers that emits hifreq and driver that is hifreq speaker.
Posted on Aug 10, 2009
alicantecoli
  • 22156 Answers
SOURCE: need electrical schematic for 1998 Suburban ac
could be something to do with the rad fan relay or reostat ,if fan doesnt work then ac clutch will not kick in
Posted on Sep 11, 2009
Starts but wont idle
Your pilot air jet is blocked. The carb will need a very thorough internal clean, if you can get it into an ultrasonic bath for cleaning that would be best.
Aug 01, 2014 | 2004 Yamaha XT 225
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
May 09, 2014 | Intermatic Malibu 300W Power Pack...
Matsui M19DVDB19 stuck on stand by
Check all the power output voltages from its main voltage regulator board. Cehck whether 5VDC and 3.8VDC are present. For more, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Schematic diagram can be available.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Televison & Video
Can i hook a wireless mic to a canon fs300
No. The FS300 does not have any provision for an external microphone.
Feb 22, 2012 | Canon VIXIA FS300 Flash Media Camcorder
My Canon FS300 will not turn on, I have the charger plugged in as well as having it plugged into my laptop, and it does not give any indication that it is charging or on, what do I do?
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Mar 30, 2011 | Canon VIXIA FS300 Flash Media Camcorder
Recently purchased a 2000 road king. It is fuel injected. it keeps flooding the plugs out. could the fuel injectors be sticking? I have pretty hot plugs in it and a new battery. I repaired a wire going to...
Yes your injectors could be sticking. The last owner may have had the PCM in the computer reprogrammed for more power (IE more fuel) and failed to do any of the other associate modifications (pipes, air filter). This will cause it to run rich, but I doubt it would flood it out. You can take the injectors out and put them in an ultrasonic bath for 30 minutes or so and this will clean them out really good. A jeweler will do this for you sometimes. Or you can purchase your own ultrasonic cleaner for around $60.00. I would start there. If your fuel system has a schrader valve somewhere on it you can attach a fuel pressure guage to it. Start the bike and then turn it off, the fuel systenm should maintain pressure, if the pressure goes down rapidly you have an injector that is sticking open.
Apr 07, 2010 | 2003 Harley Davidson FLHRCI Road King...
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Bike has good battery, but will not start. has been sitting awhile. people say fuel injector ports clogged. how do i fix? was in Iraq and ready to ride.
you will need to take the injectors out of the head and clean them. An ultrasonic bath is the best way to clean them. A good local mechnic will have an ultrasonic bath, ''.
Good luck
Nov 11, 2009 | 2005 Suzuki Boulevard C50
Aug 05, 2009 | Digitrex Cameras
Botched repair
Mar 28, 2009 | Branson H9401 1/2 Gallon Ultrasonic...
Kitchen Appliances - Others Logo
132 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
