Question about Frigidaire ATF6000ES Front Load Washer
Dishwasher sounds likes its struggling - large purring sound - but i can't find anything that is stuck or loose. I am getting a very thick white residue on all dishes after they go thru cycle. Have soaked dishes in sink to remove and can't get risedue off. What's wrong with dishwasher?
Agent Dort
  • 216 Answers
SOURCE: Cloths were soaked !Won't restart, door locks and you hear a buzzind sound ??
Greetings JohnnyWrench,
Information provided by the manufacturer would indicate a few things possibly causing this:
1) Washer was overloaded, remove some of the clothes and continue the cycle.
2) Washer load was too small. Add 1 or 2 similiar items to help balance the load.
3) Load is out of balance, rearrange clothes to allow for more balanced spin.
4) Drain hose might be kinked, straighten drain hose.
You can also find a copy of your owners manual at
http://www.frigidaire.com/products/laundry/washers/front_load/prod_ATF7000FS.asp
I hope some of this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on Apr 30, 2008
SOURCE: Dishwasher residue
there is a new product out called the Difi dishwasher filtration system. it filters the water going into your dishwasher and will solve the problem. after i hooked it up(which takes no time at all) i could not believe how clean my dishes came out. it is very affordable and fits under the sink. you can check it out at www.dishwasherfilter.com
Posted on May 02, 2008
  • 677 Answers
SOURCE: Water not draining out after wash cycle
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
aborcass
  • 2651 Answers
SOURCE: Dish washer won't drain properly
either you have a blockage inside the drain hose at the attach point under the sink , or possibly somehting stuck in the drain pump itself, preventing proper drainage, the drain pump is acessible form underneath, usually mounted ti the right side of dishwasher, "unplug first HOT WIRES"
Posted on Jan 11, 2009
onthejob5130
  • 640 Answers
SOURCE: dishwasher not filling with water
look in the dishwasher theres a little float plastic and round take your hand and pick iu and drop it if that float stuck up when dishwaser had water,,it will need a little help dropping back in slot...onthejob
Posted on Jan 18, 2009
1" thick white space down the center of the page
From the very brief description you provided, it sounds like you may have a label or something else 'stuck' to the drum. Shut down the printer, pull the drum/toner cartridge and physically look at the drum. If there is notthing on it you may have a bad laser engine. The only way to correct this would be to replace the cartridge.
Oct 06, 2011 | HP LaserJet 4050 Printer
My LG Tromm dryer started purring today. It is a constant noise while the dryer is running and sounds like a large cat purring.
The guide that the drum sits on may have been damaged or worn or maybe a piece of fabric or some foreign material is lodge in between. The top cover of the dryer can be remove so you can examine it. Of course makes sure it is unplugged before doing any of that. Most of the time the drum guide is made of plastic material and wears out too. Good luck
May 24, 2011 | Dryers
My 2002 gmc envoy has a high screech when the engine is running. the sound remains the same regardless of the speed.
Sounds like a loose belt. Check your tensioner and your belt thickness. Your tensioner could be stuck or bad which would cause your belt to be a little loose and it would slide across the pulleys instead of roll with them and cause a screech sound. Same with belt thickness only the tensioner would be as tight as it gets but the belt would be just thin enough that it wouldn't work properly. Hope that helps you.
Jan 03, 2011 | 2002 GMC Envoy
Dishwasher starts but after a pre rinse it won't
This sounds like the anti flood device has activated (due to some water on the bottom base of the washer) This device shuts of the water inlet and puts the pump out motor on (the sound you are hearing). Nothing els happens until the water on the base is dried and the faulty pipe / leak rectified.
The anti flood device is a small polystireene plate connected to a micro switch on the bottom of the washer.
Jan 20, 2010 | Dishwashers
My MacBook is making a purring noise.
it can be the cooling system, but you will have to show your machne to a reparator.
Jan 13, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Garage door is stuck half way up - opener still running
Sounds like your drive gear is bad. It is a white nylon gear just in front of the motor. It will be obvious.
Dec 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
No water coming into dishwasher
There are a couple of things to check. First we will start with the water level float. Open the door and on the floor of the washer, left side, front you will see what looks like a large cap. This is the water level float that tells the dishwasher how much water is in the bottom of the unit.
Check and see if you can push it down closer to the floor. If it is stuck in the up position, the washer "think" it is full of water and will not allow any more in. If it seems to be all the way down, pull it up and out to make sure the stem is not broken or it looks damaged in any way. Check the float chamber for debris or anything that looks like it doesn't belong.
Clean the assembly and chamber as necessary.
Let me know.
Regards,
Jul 21, 2009 | Maytag MDB5100A Dishwasher
Kitchenaid Dishwasher KUDK01ILBS1
Yes, you are at the point that where the wash motor needs to be replaced. There is no magic bullet to avoid doing the replacement.
If you want further guidance, please post back here. Ok?
Apr 11, 2009 | KitchenAid KUDK01TK - Multiple Color...
Frigidaire ATF6000ES Front Load Washer Logo
82 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
